Onkyo TX-NR838 Preamp board
  • DenisMcG
    • Apr 2018
    I recently purchased a used 838 that had gone into protect mode. Upon investigation, I found that the SR section of the preamp driver board had several shorted transistors and burnt components. This section of the board was badly burnt with some of the copper runs pulling away. I was not able to source any of the transistors, so I cut the board in three pieces and plugged the SBR section into the SR connector on the main amp board. The receiver is back up and running but only as a 5.1 system. Does anyone know where I may be able to source either an entire good board (part #bccla-1579), or even a bad board. I could isolate a good section to get back up to full 7.1.
    PS. Onkyo was of no help whatsoever.
  • madan1
    • Nov 2016
    • 719
    Re: Onkyo TX-NR838 Preamp board
    Why don't you just order a new board from a service like this https://www.eurocircuits.com ( just googled it, have not tried them )? Too bad that they do not provide any more the pcb schematic in the service manuals, so you will have to scan the original board and process it in the required format for printing.
    If onkyo does not want to provide you a new one, you have the following options - ask an authorized service to order the board for you or wait for a dead unit to show up for sale on ebay or a similar site.
    By the way how bad is the original board? Can we have some photos?
    • DenisMcG
      • Apr 2018
      Thanks for the comments. I contacted both Onkyo and the nearest authorized service rep and they both were of no help. They will not sell the board at all. I will keep my eyes out on ebay etc and hope that one comes up. I know the same board was used on the 737 model as well.
      The board was so badly burnt that I threw it out.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • jjne
        Bad DC offset on Onkyo TX NR414 - doesn't appear to be in the analogue section
        by jjne
        I have a TX NR414, well I have two actually which are both exhibiting the same issue.
        The one I've had since 2012 developed DC offset of around a volt under load on the front right speaker output. Not enough to trip the protection but enough to be noticeable in terms of sound quality. I checked the preamp board and couldnt see anything obvious. The offset is too high really to be a drift issue right?
        I put the amplifier away for a while. I managed to pick up another example with a dead HDMI board very cheaply (common on these - mine was replaced by Onkyo several years...
        07-28-2025, 07:51 AM
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
