Re: Av123 MFW-15 power supply problem
<Nevermind, i mis-read some things>
Hi, I recently bought this sub. However, the person that sold it told me that the power does not work but the sub is still usable if I hook it up to a separate amp. I was able to hook it up to my Inuke6000 DSP and the driver works.
Turning the power on the sub and set it on auto will lit up the green light but If I i select auto it will lit up the green light for a short period of time but shortly after that, it will turn back to red.
I also smelled burning smell inside the of the sub. I opened it and discovered several capacitors burn/ blew up.
As for the power supply board, the C4, R1, R2 capacitor is blown.
The power supply listed as MFW-15_POWR v2.1 and I listed in the attachment below.
I found several links that showed how to replace the capacitor to fix the hum but not to replace the other broken capacitor. Can someone point out what is the value of the R1 and R2 capacitor and which capacitor I can replace it with?
Any help would be appreciated thanks,
https://imgur.com/ZiVn2RT that is the link to fix the hum with the replacement capacitors.
Ceramic discs are 104M 50v Y5u 1nf 20%.. your resisters in R1 and R2 are different colors than mine and they are the same boards. I can't tell for sure what the color bands are on mine either sucks.Last edited by xXDigitizerXx; 02-24-2018, 03:42 AM.Leave a comment:
https://www.badcaps.net/forum/attach...2&d=1519405455
Can I get straight shot pictures wit less glares so I can clearly see the traces?
The resistors looks to bleeder resistors to discharge those 4 large filter caps, the small ceramic disc caps are for high frequency filter and they are connected in parallel with those big caps.
BTW, you also have bad brown problem, they are corrosive and conductive and must be removed.
Can we also get good clear pictures of other board as well?Leave a comment:
Yes sir, i'll update it tomorrow currently at work. Thanks for the quick replied.Leave a comment:
Can we also get good clear pictures of other board as well?Last edited by budm; 02-23-2018, 02:43 PM.Leave a comment:
https://imgur.com/ZiVn2RT that is the link to fix the hum with the replacement capacitors.Tags: None
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
Assuming...7 Photos -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... -
by madan1Good day.
I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar... - Loading...
