Yamaha RX-A760 not powering on (newbie)
  • IAH
    So, full disclosure on how I fried this AVR (this is REALLY emabrassing!):
    I was attempting the battery test with my speakers to check their polarity, and like an idiot, I unplugged the speaker wires from the speaker rather than the receiver and touched the leads to the battery. So in other words, the speaker wires were connected to the receiver and I touched the other ends to the battery! This caused the receiver to shut down and go into what I understand is "protection mode", where the receiver wont turn on until it is serviced.
    So I searched online for a diy fix and found out how to try and override the protection mode and get it turn back on (hold down "info"+"tone control" and press "main zone/power"). This did not work - the receiver clicked like it was trying to turn on, but failed to fully power up.
    I then read that it could be a fuse, so I opened it up and found a fuse on what I think is the power supply board. I replaced it, but not with the EXACT same voltage (replaced 8A 125v with 8A 250v), and I ended up blowing that fuse (could this be the problem).
    So I removed the fuse completely and then attempted the power on the AVR using the protection override method, and it turned on! But it displayed a code: PS2 PRT: 124. I have no idea what this means, but maybe someone here does.
    So, have I totally fried this thing? Is there any possibility of saving it?
    Thanks, and please excuse my ignorance!
  • tibimakai
    • Jan 2012
    • 3680
    Re: Yamaha RX-A760 not powering on (newbie)
    Most likely, you have blown up some components, at that channel.
    You will have to check all the components at that channel, and replace what is damaged.
    • IAH
      Thank you for the reply tibimakai.
      I will take a look. Any signs I should be looking for with regard to bad components?
      • madan1
        • Nov 2016
        • 722
        Here are the basics - https://www.youtube.com/watch?v=DKCSD3F3D9w
        PS2 PRT: 124 if I remember correctly this is an error associated with the power supply.. which in your case is caused by the removed fuse ( no power through the main transformer )
        • IAH
          Makes sense. And thanks for the video! I'll give it a shot.
          • Pete D
            Yamaha HTR-5460 Receiver protection code info.
            by Pete D
            Hi Guys, My first time on the forum.
            I have a Yamaha HTR-5460 Receiver that I have used for a few years. It has recently developed a problem of giving a pop in the speakers and then shutting down. This is intermittent and might happen after an hour or a couple of days of playing.
            I have put it into Diagnostic Mode and it comes up with code “PS PRT 020 B”. According to the service manual “PS PRT” signifies a power supply problem in the mains transformer, 5V or 12V DC supplies. I'm assuming that the “020 B” part of the code would define which one of these...
            11-03-2023, 07:00 AM
          • corrize
            A funny fuse story – Lumix LX100 II
            by corrize
            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
            10-19-2023, 09:58 AM
          • sanalelevenstar
            Yamaha RX-V485 receiver. After encountering a "version error"
            by sanalelevenstar
            I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
            After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
            I managed to find the service...
            09-10-2025, 01:54 AM
          • jesterace
            Samsung UE46ES8000 Blown fuse but no other signs of short
            by jesterace
            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
            09-11-2024, 03:14 PM
          • jshhh
            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
            by jshhh
            Hi guys,
            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
            Anybody know how to remove this type of fuse?
            (The fuse is toward the bottom of the image labeled F2)...
            06-17-2025, 01:35 AM
