Canton DM50 - V49 Error code
  • dobrykamil
    • Jun 2013
    • 62
    Looking for service manual or explanation of what this error code means? This is my first Canton's unit, not sure where to start from?
    Thanks in advance.
  • Curtissimo
    HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
    by Curtissimo
    Hi everyone.
    I have a HP Elitebook 850 G8.
    Serial: 5CG2324XM0
    ProdID 6L8D5EC#ABA
    It has a Winbond W25Q256JVEN Chip.
    I need to remove BIOS Password.
    I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
    Attached my dump.
    I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
    I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
    What I did:...
    08-26-2025, 04:42 AM
  • Maalobs
    Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
    by Maalobs
    I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
    The relevant service manual for the chassis is available here.
    The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
    When I short the SDM to ground I get the layer-2 error code 53.
    The inside of the TV has no damaged components and no swollen capacitors.
    In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
    04-02-2019, 01:15 PM
  • bohaboha
    error code 0x80072f8f 20000 When widows upgrade to 10
    by bohaboha
    when upgrading windows 7 to windows 10 i get this error code (title).then to correct the error i have to enable tls 1.1 and tls 1.2 in registry editor. but there I do not find TLS 1.1 and TLS 1.2 instead there is SSL2.0
    in REGISTER EDITOR on windows 7 ad can one do to correct the problem?
    Error Code 0x80072f8f 20000
    08-30-2023, 07:06 PM
  • Sus256
    HISENSE 65E7KQ PRO - no boot
    by Sus256
    Hi all!
    HISENSE 65E7KQ PRO
    RSAG7.820.13512 - chassis
    MT9618BAATAB - cpu
    RSAG7.820.12059 - power
    HD650Y3U77 - panel
    KLM8G1GETF - emmc
    Replaced emmc.
    Terminal log
    UART
    AC_ON
    E-B
    FDE enabled
    06-01-2025, 02:11 AM
  • CdDvdFlash
    Hitachi HTA-DD3W AV Receiver Error Code -Protect-
    by CdDvdFlash
    I have a Hitachi HTA-DD3W AV receiver and when I got it I tested it working fine with speakers but it needed a clean inside because it had signs of moisture in it but it was fully dry with bits of wood chips, I guess this was left in a shed so I fully disassembled it and cleaned it with isopropyl alcohol very carefully, some de-soldering was also needed but now its very clean, luckily there was no rust on any components and all the capacitors are fine with no bulging. When I turn it on I hear a relay switch on then a few seconds later another relay switches on or off and the display has a "-PROTECT-"...
    07-10-2023, 06:05 AM
