Sherwood RD-8108R Audio Amplifier
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    I have the above unit that switches on and after a few seconds at most goes into standby mode. Whilst on (that is before going back into standby) the display is functioning.
    Has anyone the service manual for this model or perhaps could point me in the right direction.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sherwood RD-8108R Audio Amplifier
    Check PSU Trans, Diodes, etc......Then look at the Power Amp Output Semiconductors...any suspicious e-caps or scorched resistors??
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Thanks for your reply. Found a -15V three terminal 7915 regulator with -27V input and no output.
      Removed it and tested it on a power supply and it worked OK giving -15V output but I had no load connected.
      Put it back in and still had -27V input and 0V output.
      Added -15V from external power supply and the amplifier is up and running.
      Will replace the 7915 regulator
      • petehall347
        • Jan 2015
        • 4429
        check the ground connection for the regulator
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          I now have the amplifier up and running but if anyone has the schematic for it I would very much appreciate it.
          Regards
          • petehall347
            • Jan 2015
            • 4429
            http://www.givefile.net/smanuals/_av.../rd-8108r.html
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Thanks for the link but it seems to want to download unwanted files.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                As I said earlier it is now up and running after changing the -15V regulator.
                Have run it over the last few days, however on two occasions it has emitted an extremely load pop from the speakers and gone into standby.
                Leaving it for a few minutes and then coming out of standby the amp will work again as though nothing un-towards had happened.
                • samson7point1@yahoo.com
                  Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                  by samson7point1@yahoo.com
                  The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                  The player processes the audio signal using two different reference frequencies. The "R"...
                  04-30-2024, 11:22 AM
                • eccerr0r
                  Frying amplifier finals... audio, not rf...
                  by eccerr0r
                  Well for RF transmitters, transmitting without an impedance matched antenna and if the transmitter doesn't have automatic limiting... kiss the final transistor goodbye and chalk one up to something you killed.
                  But that's not the same way with audio amps for the most part, well, at least the wavelength of audio on copper is so long that you get all of it back anyway but the transistor is fine with it...
                  So how are people destroying finals in their audio amplifiers then? Heh.
                  Are people shorting their outputs or something, overdriving output to a too big speaker?...
                  11-27-2021, 12:30 AM
                • MrCommunistGen
                  Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                  by MrCommunistGen
                  My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                  I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                  07-12-2021, 05:11 PM
                • Babbar
                  by Babbar
                  04-12-2024, 01:12 AM
                • RetroComputingGrotto
                  TDA2030A Audio Power Amplifier Question
                  by RetroComputingGrotto
                  My boss always says "the only stupid question is the one not asked" so at the risk of asking a stupid/obvious question I'm going to one any way...
                  I've got a pair of speakers with an amp built in to them in for repair and on inspection I can see the TDA2030A amplifier ICs have blown (so I've ordered some spares which should arrive soon):
                  My quesion is with regards to the white paste you can see on the TDA2030A and heatsink, I'm assuming this is just some thermal paste and if so is it a special kind or will the grey thermal compound that I have...
                  10-29-2024, 08:25 AM
