Fisher RS-1056: Cannot Restring Dial Cord
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Hello all. I'm trying to restring the dial cord on my Fisher RS-1056 stereo receiver, but I can't figure out how it goes on the tuner shaft, and the guide in the service manual is no help. Can anyone please help? Thanks.
    Service Manual:
    The restring guide is on page 9.
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
  • R_J
    • 9634
    Re: Fisher RS-1056: Cannot Restring Dial Cord
    How it is wound around the rear of the shaft is shown at the front of the shaft. The lower line from the drum goes around that pulley and under the shaft closest to the flywheel, it make 3 turns and exits at the bottom rear of the shaft and goes to the pulley far left (in picture)
    • TechGeek
      Computer Geek
      • Jan 2015
      • 2254
      well how is the line wound in the drum?
      sigpic
      • R_J
        • 9634
        does this make sense? I believe that screw on the end pulley near the drum should be loosened, then when the string is in place you can tighten it so its not slipping
        I see in the parts list there is also a spring inside the drum, it's possible one end (or maybe both ends) connect to the string. Are you replacing the string or just re installing the original
        I found this picture, looks like one end of the spring connects to one of the posts in the drum and the other end of the spring connects to the dial string (looks like the spring connects to the shorter end of the string, the one I marked green)
        I found that picture here http://audiokarma.org/forums/index.p...0-nice.291091/
        • redwire
          • 3912
          Usually in the drum is a tension spring. I can't see any tensioner in the pic, where is it?
          Take a look at this similar diagram, note the use of masking tape to keep things from falling out, and cranking the dial full CW before starting.
          These things are a real test of patience....
          • R_J
            • 9634
            When the drum is this small there is not much room for a large tension spring, Its not marked on the string diagram but is listed in the parts diagram. I believe the pulley ass'y rear is the main tensioner
            • TechGeek
              Computer Geek
              • Jan 2015
              • 2254
              I know, this is an old thread, but can anyone please provide a picture showing how the line is wound in the drum? Had to destring a few months ago and now am trying to restring.
              sigpic
              • vestaviascott
                Dial Cord Hell! Radio Shack SW-100 (Venturer 2959, Rhapsody RY-610)
                by vestaviascott
                I'm looking for the dial cord winding settings for this radio!
                I spend most of a whole day yesterday trying to figure this out. I just need to know how many turns for the tuning knob stylus to get me started, then how many on the lower and upper bobbins on the first cord pulley (there are two on either side of the tuning band area).
                The dial cord system has a central gear where the dial cord spring and stay is, then the tuning knob stylus and two small rollers each with a small and a larger bobbin holder. I finally figured out how to wind the cord on those bobbins...
                06-07-2020, 08:36 AM
              • mojos911
                Fisher and Paykel 10 kg top-load washing machine LED identification
                by mojos911
                I'm looking for a replacement for the red LEDs used in a Fisher & Paykel 10 kg top-load washing machine. Each LED is about 6 mm long, mounts flush to the PCB with side tabs, and measures around 1.7 V forward voltage in diode-test mode. The marking on the body is “3A56,” but I can't find any matches for that in part searches. I've attached photos to show the shape and mounting style.
                If anyone has sourced an equivalent or knows a suitable replacement, I'd really appreciate your input. Thanks in advance for the help!...
                01-17-2025, 06:54 PM
              • Evets
                Fisher TAC-M47 schematic
                by Evets
                Can anyone help me with a schematic for a Fisher TAC-M47.
                05-17-2024, 04:35 AM
              • drunkendwarf
                1986 Fisher television B+ Low
                by drunkendwarf
                Hi guys, i have a 1986 Fisher PC420 television. Chassis #A7R-42000
                it works but has no picture width and some barrel distortion. i narrowed it down to low B+ 89volts. service manual says it should be 111volts.
                it uses these Sanyo hybrid IC chips for error detection and drive that are discontinued and i cannot find anywhere. i found one post regarding a Sanyo TV with same symptoms and the resolution was the error detect module.
                Part # JU0161 and JU0148
                i'm now looking at bypassing that error detect to the optocoupler circuit somehow...
                04-26-2023, 03:43 PM
              • RolandVossen
                Kenwood Chef KVC50 / KVL60 / KVC5000 / KVL6000 / KVL6030 / KVL6050 kitchen machine repair
                by RolandVossen
                I am attempting to repair a KVC50 kitchen machine. Problem is that speeds 1..5 on the speed dial do not work at all (motor is not engaged). The 'reverse' and 'slow' settings on the same dial however work properly. I removed the dial, its PCB components seems to be basic: a potentiometer, a microswitch, a couple of LEDs and a couple of SMD diodes or transistors. The dial has three cables with three connectors that hook up to the motor controller PCB. One connector (3 pins) for speed, one connector (5 pins) for the LEDs, and one connector (2 pins) for a safety switch that is...
                03-16-2024, 03:55 AM
