Guitar Amp Noise
  • benni
    • Jan 2017
    • 17
    Guitar Amp Noise
    Hey everyone, I hope this is the right place for this.
    Anyway, I'm getting some fairly gnarly noise coming from my tube amp, in a bad way. It's more of a hiss than a hum, it isn't consisent (has some pops and clicks), and isn't audible when in standby mode.
    Any ideas what could be causing it - tubes or even speaker perhaps? I had a power tube die on me before, but that just killed any output altogether, so I'm fairly sure it's not that. Otherwise, I'm pretty stumped!
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Guitar Amp Noise
    One of the preamp tubes going dud, perhaps?
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      It would help to know what type a Amp it is. Model # Brand name? Also, if you have a service manual that would help? Do you have any electronic test equipment?
      • Longbow
        • Jun 2011
        • 623
        Any ideas what could be causing it?
        Yes, lots of ideas. This is where your career as an electronics engineer begins. How about starting with the schematic? Keep in mind that even when new, most guitar amps have quite a bit of noise, not including the noise picked up when you plug in an instrument.
        Is it plugged in?
        • peter.uttley
          • Jul 2017
          • France
          I'm pretty sure it will be a power tube problem ..what's the amp ?
          • petehall347
            • Jan 2015
            • 4426
            • United Kingdom
            clean the valves pins and sockets ..
            you could first try gently rocking them to see what happens .
            • Concordian
              • Aug 2017
              • 3
              Benni, I'm assuming you're aware of the "normal" noises that can occur even with good amps (e.g. from guitar cables that aren't connected to a guitar, and from single coil pick-ups that pick up 60 cycle magnetic fields from nearby electrical appliances) and that you've eliminated those as potential causes.
              That said, I've done so (eliminated those) with a Fender Hot Rod Deluxe III. Even without a cable plugged into the unit, it has white noise (hiss) and crackles and pops, at times. As it turns out, this is a common problem with these units, and they are supposed to be fixable by installing higher quality replacement components from one or another of the following kits:
              https://www.fromelelectronics.com/co...ucts/hrdx-mods
              Even Fender puts cheap caps in their tube amps, appareltly! And if you look at his other kits, I believe every one of them is for a Fender amp (i.e. several of Fender's other models appear to also suffer from component quality issues).
              Since discovering those kits and the info that accompanied them, I got busy studying a schematic for an old 80's 15 watt solid state Peavey amp, then spent some time looking over its circuit board. Even without a cable plugged in, it was putting out whitenoise and (60 cycle) hum, especially on its distortion/gain channel, when gain was turned up. It was a horridly loud, nasty sound!
              After measuring voltage drops and taking a look at the caps (capacitors) on the board, it became pretty clear that the caps had never had high enough voltage ratings to be safe in the circuit, given the ranges that can result from the tolerances of other components (i.e. how close they're guaranteed to be to their stated values) in the system. One capacitor was being overtaken by a voltage that exceeded its rating by 20% (30 volts across a 25 volt cap). Another was very close to its 35 volt limit.
              Given the age of the caps, I figured it best to simply replace them all. I have some Nichicon caps on order that are all rated at 63 volts, each. Hopefully I'll be able to get those installed, soon, and let you know how it turns out. If that doesn't completely clear things up, I'll go in and begin to test diodes and resistors. But whatever the results, I'll try to let you guys know how it all turns out.
              • Concordian
                • Aug 2017
                • 3
                Actually, I'm only replacing the electrolytic caps. I wasn't concerned about the ceramics or whatever other types might be in there.
                • Longbow
                  • Jun 2011
                  • 623
                  Well it is all very nice to blame everything on incorrect part values, but I'd first like to see a schematic showing some of those incorrect voltages. When a number of capacitors start leaking or failing, incorrect d.c. voltages can appear anywhere and everywhere.
                  Is it plugged in?
                  • tony359
                    by tony359
                    11-28-2023, 05:18 AM
                  • MegaZAC
                    Onkyo TX-SR805 noise in one channel
                    by MegaZAC
                    Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                    Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                    There's some logic behind it. As soon as I select an input I get only left...
                    04-23-2025, 10:09 PM
                  • DCJack
                    B&K 707 tube tester. I need help.
                    by DCJack
                    Hi everyone!
                    I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
                    Initially I noticed that I was not getting the red on-light to turn on, but it...
                    03-05-2024, 05:05 PM
                  • courtcircuit
                    Philips HTS8000 home cinema noise problem
                    by courtcircuit
                    Hello
                    I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                    Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                    Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                    I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                    Removed each of tyhe boards
                    02-08-2025, 08:22 AM
                  • Schoenradt
                    ECH81/6AJ8 Vacuum Tube Question
                    by Schoenradt
                    Recently I acquired an Eico HFT 92 AM/FM radio made back in 1958. The unit has had some decent modifications done such as replacing the rectifier tube with silicon diodes and replacing the main filter capacitor with electrolytic capacitors. When I powered it up FM wouldn't tune past 105Mhz. I checked the FM tuner front end assembly and found a capacitor not soldered to the coil from the Plate B+ to and ground on the other side of the coil. Some calibration was needed on the trimmer capacitor on the tuner. My question is AM is extremely weak. When I tap on the tube I get all kinds of snapping and...
                    06-10-2021, 05:49 PM
