Pioneer vsx-1021-k get picture no sound
  • madan1
    • Nov 2016
    • 682
    • Bulgaria
    Re: Pioneer vsx-1021-k get picture no sound
    Is there any sound on the subwoofer preout?
    If you are able to reach connector cn2103 (audio assy pcb) <-> cp410 (main amp assy pcb ) you can check if there is any preout signal.
    You should also check the power supply of the volume/switch chip - +/-7 volts ( page60 ) - kTC3209y and KTA1281y convert 12 to 7 volts
    • CapLeaker
      Leaking Member
      • 8184
      you'd have to look at page 24 and 25 of the service manual and do some testing. I'd recommend an oscilloscope, so you can actually "see" things, while probing around. I doubt that there is any sound at the pre-out channel, but it can't hurt to try.
      • Packard93
        • Jul 2016
        • 81
        YESTERDAY I did a continuity test for that . i followed the schematic and did some continuity checks all were good. I think If i can find a needle lying around in the house Ill jump that location.
        • Packard93
          • Jul 2016
          • 81
          Check the AUDIO Assy CN5 pin 5
          (12V), pin 7 (- 12V). oK on this step page 24 .
          • CapLeaker
            Leaking Member
            • 8184
            At this point I would check the input of the volume knob for audio, also make sure that there is nothing stuck / bent inside the headphone jack. With an oscilloscope it would be easier hunting for where the audio goes missing. Other than that, as long as the relay energizes, and it should at 3.3V, it's all right.
            • Packard93
              • Jul 2016
              • 81
              ok I got -6.87 and + 6.87 there . on thos two.
              • madan1
                • Nov 2016
                • 682
                • Bulgaria
                #27
                well... good and bad news - the good is that the voltages are fine and the bad - you are out of easy and cheap repairs.
                • Packard93
                  • Jul 2016
                  • 81
                  [url]So does this elimate all the other boards except the dts chip board with the hdmi since there is not voltage testing to determine it without a ociliscope testing . So would U concluded that I need to pay attention to this as my next attempt or replacing the board. What would u recommend try this---> https://youtu.be/U1qiMVW8Pog
                  So with all those voltages I tested means I have no failed circuits if I have voltages on other boards I can say that the dts chip is to blame ?Or am I not out of the woods yet?
                  • CapLeaker
                    Leaking Member
                    • 8184
                    makes no sense to continue without an oscilloscope.
                    • budwich
                      • Jul 2015
                      • 3097
                      on your original problem "description", are you saying you get no sound from any processing selections / types? or just "pure direct"?
                      can you post a picture of the front of the display of the 1021 when you are setup to play a "non pure direct" processing choice? then again (picture) with "pure direct" (if there is a display). The "remote" that you are referring to is the "windows remote" not the OEM remote... right?
                      • budwich
                        • Jul 2015
                        • 3097
                        another question.... are you using a manufacturered BD disc or a "ripped disc" as your source?
                        • budwich
                          • Jul 2015
                          • 3097
                          lastly, have you checked the audio settings in particular those associated with hdmi. Further, with respect to my previous questions relating to processing, have you tried analog source inputs? My guess based on quick reads is that you have a "finger problem" associated with the settings of the receiver. :-)
                          still further: what sounds settings are on your tv?
                          • Packard93
                            • Jul 2016
                            • 81
                            Ive tested all inputs with both xbox 360 and computer with 780 ti . Xbox 360 can get video on all inputs of the 1021-k . Ive tried all pure direct direct autosurrond . No sound . Ive tried analog inputs too no sound . Ive switched to no processing so I get analog . No sound.Ive read numerous post on the 1021-k went it first release it had alot rma on the hdmi board . I asked a guy on ebay about his . His game him sound through all inputs after it wamed up for 6 months then one day all it did was the same thing as mine video only through the hdmi cable and analog. So I think I have this issue as well.
                            • budwich
                              • Jul 2015
                              • 3097
                              I think I have seen similar posts before (actually avsforum)... anyways, iirc correctly there is an incoming switching board / chip that doesn't sound like it is doing anything good for you especially since you can't even get analog thru.
                              Having said that, what does your front display on the 1021 show for status on the incoming signal and processing?
                              • budwich
                                • Jul 2015
                                • 3097
                                one other thing... you mentioned the hp_det earlier. IF you unplugged the power to the unit and then plug it back in, what does the front display show... does it display anything about "HP connected" or something like that. This "status" is only shown once during power up IF for some reason the unit "thinks" it has headphones plugged in. Subsequent plugging / unplugging of HP does not show this "status" again IF the system does not see a "physical change". Your unit could have issue with the jack / board.
                                As a test, you should be able to plug in head phones and see if anything changes / is displayed.
                                • Packard93
                                  • Jul 2016
                                  • 81
                                  https://drive.google.com/file/d/0Bzc...ew?usp=sharing
                                  Ive even had the headphone board disconnected https://drive.google.com/file/d/0Bzc...ew?usp=sharing TWO LInks one with pcm direct is without headphonee connected and the stereo one is when headphone jack is connected.
                                  • Packard93
                                    • Jul 2016
                                    • 81
                                    I can do any processing but I never get a sound .
                                    • Packard93
                                      • Jul 2016
                                      • 81
                                      Headphone jack if were stuck I dont think Id get pcm direct with a stuck jack .
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        I think we have a communication problem.... let's go slow... slower.
                                        First... get out of the digital domain. Input an analog audio signal some how.
                                        Next, plug in a headphone set to the receiver. Do you hear the analog audio signal in the head set. IF not, then your issue is near the front end of the receiver as I do believe the analog signal comes basically thru a switch IC and then is sent to the amp section AND the headphone output jack. No sound, likely means no switching which is controlled by the main controller unit.
                                        Further, your picture (link) is hard to see because of reflection... :-( but from the picture detail that I can see, there doesn't appear to be any channel lights indicating what channels are being used / assigned.
                                        PS. I notice you have posted in the avsforum also.
                                        • madan1
                                          • Nov 2016
                                          • 682
                                          • Bulgaria
                                          #40
                                          By the way, did you try to reheat the ball soldered chips on the hdmi board?
                                          • grimacelord
                                            Pioneer VXS-D902S Reciever - Filter Capacitor Question
                                            by grimacelord
                                            I have a Pioneer VSX-D902S receiver that I am trying to replace the 2 large 8200uF 80V filter capacitors on.
                                            I have already removed the capacitors and ordered replacements, but I made a mistake in ordering. The original capacitors are Pioneer ACH1202 80v 8200uF and have 4 pins. The capacitor replacements I bought are Nichicon 80v 8200uF and only have 2 pins.
                                            I was wondering if I could still use my replacements even though they only have 2 pins. Obviously I'd have to extend the pins of the capacitor to allow them to reach and fit through the...
                                            01-12-2023, 02:40 PM
                                          • Bushcat
                                            Pioneer PL-X9 motor speed control wobble
                                            by Bushcat
                                            I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
                                            Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
                                            BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
                                            05-24-2023, 03:36 AM
                                          • EduCabral
                                            [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
                                            by EduCabral
                                            I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
                                            While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
                                            🔧 Details:
                                            • Model: YT-M06
                                            • Interface: Pioneer 1
                                            • MCU: Fujitsu MB89F202
                                            • Goal: Find a valid .bin firmware file or memory dump from a working unit
                                            I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
                                            07-15-2025, 12:26 AM
                                          • pixelcap
                                            Pioneer Kuro Pro 111FD 8 red blink error
                                            by pixelcap
                                            Pioneer Kuro Pro 111FD 8 blink red LED.
                                            I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
                                            So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
                                            based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
                                            10-06-2024, 11:26 PM
                                          • RatherLoopy
                                            Pioneer VSX-44 receiver HDMI dropouts
                                            by RatherLoopy
                                            I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                                            I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                                            And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                                            05-26-2023, 03:54 PM
