Pioneer vsx-1021-k get picture no sound
  • Packard93
    • Jul 2016
    • 81
    Im running reciever PIONEER VSX-1021-K using bd input from pc and outputting to my samsung 46 inch led.Im trying to use pure direct that suppose to bypass the dsp on this reciever from my readings how DIGITAL SIGNAL PROCESSOR. .Im using A SPEAKER OUTPUTS .
    I have tested this setup on my denon 2808ci and its always had sound .
    This is what the read me says on Pioneer website for firmware revisions . I see people with same issue but have never heard anyone refer to there firmware as the culprit of the no sound.
    CHANGE HISTORY (Integrated firmware)
    MODEL : VSX-1021,VSX-921(excluding VSX-921-K/UXCNCB),VSX-1026,VSX-926,VSX-51,VSX-50
    [Integrated version : 0.236]
    Official version : 1-205-081-111-089
    Main : 1.205
    Sub : 1.081
    DSP : 1.111
    Bridgeco : 1.089
    Fixes the following issues. (Modification of BridgeCo firmware)
    - Audio is delayed with Air play by using few devices (Related QI : B2017218, B2047210)
    - Audio is intermitted with the end of FLAC file
    - Cannot play the certain MP3 file
    (Play the file which is not selected, Change to other file during playing, Title of the other file
    is displayed.)
    - Improvement of performance of PAUSE function
    - Server error occurs when playing AAC file from Push controller
    - Performance of Plug Player is slow
    [Integrated version : 0.219]
    Official version : 1-205-081-111-073
    Main : 1.205
    Sub : 1.081
    DSP : 1.111
    Bridgeco : 1.073
    Fixes the following issues. (Modification of main firmware)
    - No video & audio output when connecting with HDMI extender (CE labs HM1CK-3)
    - No video & audio output from HDMI when turning on the power.
    - No output from channel except on front L/R when inputting multi channel LPCM of BDP-4110 from HDMI
    - No LFE output when setting operation mode to basic.
    - No sound of center channel under the following conditions.
    1) Connect only front SP
    2) Advanced surround mode
    3) Multi channel source
    4) Set Dialog E to flat
    [Integrated version : 0.213]
    Official version : 1-151-081-111-073
    Main : 1.151
    Sub : 1.081
    DSP : 1.111
    Bridgeco : 1.073
    Countermeasure against UE33 error
    (* If UE33 is displayed on FL display, network features become unavailable.)
    [Integrated version : 0.164]
    Official version : 1-151-081-111-031
    Main : 1.151
    Sub : 1.081
    DSP : 1.111
    Bridgeco : 1.031
    - Large noise is heard when virtual surround is on
    - Large noise is heard under the following condition
    1) Input LtRt signal of DTS-HD/DTS
    2) No center speaker
    3) ALC mode : ON
    - Cannot play the DTS-HD signal from certain equipment(*)
    (* Such a equipment does not exist in the market now)
    - Correction of GUI for Airplay
    [Integrated version : 0.125]
    Official version : 1-125-081-102-031
    Main : 1.125
    Sub : 1.081
    DSP : 1.102
    Bridgeco : 1.031
    1st release version
  • Packard93
    • Jul 2016
    • 81
    Re: Pioneer vsx-1021-k get picture no sound
    tHERE Is a status key on the reciever remote for pcm status It matches the input that I show on the reciever properties under playback it will show the 4400 hz or if change it to 4800 khz in windows it wil show that . So I know there communicating with windows 7. I see the volume bars move in windows 7 when I hit test or if I play something Like youtube or movie on my computer I see volume bars . I just dont hear anything from speakers. I get video cause Im hooked up to samsung 46 inch led I just dont hear any sound.
    • Packard93
      • Jul 2016
      • 81
      status frequency in windows when change will update the frequency under the status key on remote for the pcm . So if i change to 16 bit 48khz in windows and it was 44khz prior reciever will show the proper 48khz when I change it so I know I have connection between reciever a pc. I have video on my samsung 46D6000FXZA led from reciever and I got a connection to reciever cause there is pc desktop on my samsung TV 46 INCH 46D6000 cause Im feeding hdmi to the reciever from pc to the bd input .but I dont have sound. Stumped on that.
      • Packard93
        • Jul 2016
        • 81
        anyone know what to look for inside the unit to repair . I have multimeter ready I dont have schematic for how it operates to see where the issue is?
        • Packard93
          • Jul 2016
          • 81
          Checked IR-ASY IN service manual shows 6volts I show 3.3 volts .
          I see a transistor circuit. Would that cause the voltage drop or is that compacitor issue?
          • madan1
            • Nov 2016
            • 722
            • Bulgaria
            are you sure you are measuring the correct power line?
            for sure u have and a 3.3v power supply.
            • Packard93
              • Jul 2016
              • 81
              ok after I reread it . Its says 0-5volts so 3.3volt is tolerable .Im reading the flowchart . Yes Im reading the ir assy on the flow chart. The 19 pin on the ir assy not the pins on the main.So does this mean the volume will be low out of the head phones. Or is that 3.3 volts cause the volume knob is related to the amount of volume selected?
              • Packard93
                • Jul 2016
                • 81
                Check the BR Assy CN2108 pin 23
                (HP_DET) is low with connection
                of the headphones <<----- Does this mean check the cable for continuity?
                • Packard93
                  • Jul 2016
                  • 81
                  f-rly seem to getting volts 4.8 . and center relay volts out of ir asy shows volts . When i change the channels with the channel button on front panel I see active volts going to relays.but I still need to investigate why I have no sound from outputs.
                  • Packard93
                    • Jul 2016
                    • 81
                    • Packard93
                      • Jul 2016
                      • 81
                      Ok unit comes on everything but sound works controls all work lights up ok . No sound No error codes Any ideas appreciated .
                      • Packard93
                        • Jul 2016
                        • 81
                        https://drive.google.com/file/d/0Bzc...ew?usp=sharingTested 3 transistors on the main assy board bottom . They look shorted . I have DVM ON diode setting and I show voltage on all three pins . Im not sure if I did the test right cause Im unsure which is gate . Need help . Can someone tell me how to test the transistor 7805a on main .There the 3 on main assy . If those are bad will my sound be out from these? I did a complete test on flow chart for no sound all voltages were fine now It says main is needed replaced but I tested 3 transistors and my DVM SHOW they looked short . Anyone know the proper way to test them? Pic link up.
                        • madan1
                          • Nov 2016
                          • 722
                          • Bulgaria
                          Those look like power regulators.
                          7805 is the +5V output one... most likely you have and 7905 there which is the -5V ( or vice versa ).
                          Instead of waiting for an answer, google the chip like "7805 pinout" and go to images. You will get smthing like this
                          This way you will speed up the troubleshooting
                          On the input pin most likely the voltage should be 8~12V
                          on the output you should have 5~5.5
                          (check the service manual for the exact values)
                          Keep in mind that the pinout of the 7905 different.
                          • Packard93
                            • Jul 2016
                            • 81
                            those look like power regulators.
                            7805 is the +5v output one... Most likely you have and 7905 there which is the -5v ( or vice versa ).
                            this way you will speed up the troubleshooting
                            on the input pin most likely the voltage should be 8~12v
                            keep in mind that the pinout of the 7905 different.
                            service manual shows part number as kia7805api junction j29 j30 & j31 When I look at chip I show with magnifining glass I can read 7805A kia is above .
                            FOUND SOME KIA7805API JUST LIKE SERVICE MANUAL HERE https://www.utsource.net/search.aspx...7805API&page=1
                            • tibimakai
                              • Jan 2012
                              • 3680
                              It is very possible, that is a DTS chip problem. A lot of these and newer receivers, get an U22 error, which is most likely the DTS chip has un-soldered itself, from the excessive heat.
                              • Packard93
                                • Jul 2016
                                • 81
                                No errors ever pop up . Reciever video hdmi tested with xbox 360 all show video . Just no sound. I dont have any errors that would indicate any problems . It powers on normally . I did a flow chart test from service manual . all test came back normal . Im think problem is on main assy . The digital board I would get error code Like you say. But since I dont have error 22.The service manual says to check the main assy which is the bottom board. Service manual has me check things on main assy which is bottom nothing to do with the top board where the error would appear if there were a problem there.So there has to be more testing for the bottom board to see what is the issue with no sound .What can I check on main assy . Here is a pic of the main assy in service manual
                                • CapLeaker
                                  Leaking Member
                                  • 8332
                                  Weird. Either it is something stupid like the HDMI cable not carrying any audio (not all HDMI cables carry the audio), something in the digital processing unit is not turning on or missing power or a cold solder joint.
                                  If you were streaming from your computer through HDMI, you would have to turn the HDMI audio on.
                                  If you can verify that audio is doing into the A/D converter all right, then check it again at D/A converter output. Other that that, you can try using heat, cold, flexing or pressing on sections of the PCB and see if that does something?
                                  • Packard93
                                    • Jul 2016
                                    • 81
                                    I know hdmi audio cable is sending audio . Cause it works with my DENON 2808 CI AMP . These cables are all brand new 1.4 versions . These cable work with all my other devices projector xbox 360 all work with denon amp I get pic and audio with denon receiver . The 1021-k works completely but no sound . I can hear the second click meaning that the chip is working from what I can tell watching youtube video when chip is working. There is two clicks for good working . But Im wondering if there is cold joint .There must be more verification board testing. Im going to do more testing on some more locations listed in the service manual under the no sound flow chart in there. pg. 24 https://drive.google.com/file/d/0Bzc...ew?usp=sharing
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      Did you do a microphone calibration?
                                      • Packard93
                                        • Jul 2016
                                        • 81
                                        Check the BR Assy CN2107
                                        pins 5, 7 signals. I suppose to do this as next step . Can I use dc on dvm to do this check? I checked for continuity test for the connector previous step now I need to check signals.I think I need a meter that can measure hz .
                                        • grimacelord
                                          Pioneer VXS-D902S Reciever - Filter Capacitor Question
                                          by grimacelord
                                          I have a Pioneer VSX-D902S receiver that I am trying to replace the 2 large 8200uF 80V filter capacitors on.
                                          I have already removed the capacitors and ordered replacements, but I made a mistake in ordering. The original capacitors are Pioneer ACH1202 80v 8200uF and have 4 pins. The capacitor replacements I bought are Nichicon 80v 8200uF and only have 2 pins.
                                          I was wondering if I could still use my replacements even though they only have 2 pins. Obviously I'd have to extend the pins of the capacitor to allow them to reach and fit through the...
                                          01-12-2023, 02:40 PM
                                        • Bushcat
                                          Pioneer PL-X9 motor speed control wobble
                                          by Bushcat
                                          I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
                                          Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
                                          BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
                                          05-24-2023, 03:36 AM
                                        • EduCabral
                                          [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
                                          by EduCabral
                                          I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
                                          While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
                                          🔧 Details:
                                          • Model: YT-M06
                                          • Interface: Pioneer 1
                                          • MCU: Fujitsu MB89F202
                                          • Goal: Find a valid .bin firmware file or memory dump from a working unit
                                          I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
                                          07-15-2025, 12:26 AM
                                        • pixelcap
                                          Pioneer Kuro Pro 111FD 8 red blink error
                                          by pixelcap
                                          Pioneer Kuro Pro 111FD 8 blink red LED.
                                          I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
                                          So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
                                          based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
                                          10-06-2024, 11:26 PM
                                        • RatherLoopy
                                          Pioneer VSX-44 receiver HDMI dropouts
                                          by RatherLoopy
                                          I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                                          I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                                          And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                                          05-26-2023, 03:54 PM
