B2031A active studio monitor repair/diagnosis
  • matrx10503
    • Dec 2015
    • 5
    • US
    Can anyone give me some guidance.
    Behringer Truth B2031A
    Here is the issue. 1 of my studio monitors blew and now won't turn on. The other one in the set is still fine and working.
    The monitor was not in use when it happened. I came back to my studio one day and the cone on the 6" woofer was blown out and almost shriveled up (indicative of heat). The woofer is seized up and does move freely. I do not know the status of the upper tweeter speaker.
    I plug the monitor in and no red light, no green light when the power switch is clicked.
    I have now removed the amp from the back of the enclosure. Nothing smells burnt (electric burn/blown smell) and I cannot see any defects on the board itself.
    My question is, how do I go about diagnosing, with a multi-meter, if I need to just replace the amp and possibly woofer to get it working again.
    I can supply pictures to familiar everyone with the amp and wiring setup.
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: B2031A active studio monitor repair/diagnosis
    Well, to begin with, some photos of the "almost shriveled up" woofer would help, as well as some well-lit and well-focused photos of the top & bottom of the circuit boards inside.
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • matrx10503
      • Dec 2015
      • 5
      • US
      Sorry, I need to separate the amp from its heatsink/cage to get pics of the bottom circuits.
      Upon further review, It does seem like one of the two large caps is bulging upwards a little.
        What are the P/N of those IC amps attached to the heat sink? It more likely that the output shorted out and dumped large DCV to the voice coil, I do not see any speaker protection relay.
          • 31068
          visible in the second pcb foto
          LM3886T
          why is it that the "better" the brand name, the more glue & flux you find in them?!!
            • 31068
            datasheet
            https://cdn.badcaps-static.com/pdfs/...d0fd7f1e56.pdf
            • Khron
              • Sep 2006
              • 1350
              • Finland
              Press down on that black PVC top to see if the metal can itself underneith is bulged, or if just the top cover's sitting tall of the top of the can.
                Check the resistance between the output pin and -VCC pin, output pin and +VCC pin to see if the output devices shorted out (or have very low resistance) to the VCC.
                • Khron
                  • Sep 2006
                  • 1350
                  • Finland
                  For what it's worth, i seem to remember reading about LM3886TF's (the isolated-package version) failing in Event ASP series monitors on several occasions, possibly due to overheating ie. insufficient cooling. Well worth investigating in this case as well.
                  Also, with the speakers disconnected, checking for DC on the speaker output connectors would be another step.
                  • matrx10503
                    • Dec 2015
                    • 5
                    • US
                    Sorry everyone, I did not get the reply notifications.
                    Here are the pictures of the bottom of the board:
                    @Khron
                    I'm definitely thinking its a capacitor issue and all the other components like the 3 IC's are probably fine.
                    One of the 6800uF/50V snap-in capacitors is bulging upward and not to mention when I shake the whole board, I can hear that specific cap. in the inside of it moving around.
                    • Khron
                      • Sep 2006
                      • 1350
                      • Finland
                      Well, it definitely can't hurt to get rid of s**t-brand caps
                      • matrx10503
                        • Dec 2015
                        • 5
                        • US
                        I see -VCC and +VCC. I don't know what the output pin is.
                        • Khron
                          • Sep 2006
                          • 1350
                          • Finland
                          Google is your friend
                          http://lmgtfy.com/?q=lm3886
                          The first result should answer your question.
                            Did you look at the spec sheet?
                            The spec sheet page 2 clearly shows Pin 3 is the output pin.
                            I hope this is not going to be another long thread.
                            • Khron
                              • Sep 2006
                              • 1350
                              • Finland
                              One other way to find the output pin is to remember that the output of the amplifier(s) goes straight to the speakers / speaker connectors...
                                HP ZBook Studio G4 + DreamColor 27x monitor Mobile workstation Studio Specification for Upgrade or Repair
                                This specification for the HP ZBook Studio G4 + DreamColor 27x monitor Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Studio G4 + DreamColor 27x monitor boardview and Studio G4 + DreamColor 27x monitor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                09-06-2024, 06:10 AM
                                HP ZBook Studio G4 + DreamColor Z27x Studio Display Mobile workstation Studio Specification for Upgrade or Repair
                                This specification for the HP ZBook Studio G4 + DreamColor Z27x Studio Display Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Studio G4 + DreamColor Z27x Studio Display boardview and Studio G4 + DreamColor Z27x Studio Display schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                09-06-2024, 06:00 AM
                                by momaka
                                03-15-2023, 10:17 PM
                                MSI Creator Z16HX STUDIO B13VFTO-053 Notebook Z16 HX Studio Specification for Upgrade or Repair
                                This specification for the MSI Creator Z16HX STUDIO B13VFTO-053 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z16HX STUDIO B13VFTO-053 boardview and Z16HX STUDIO B13VFTO-053 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-07-2024, 06:38 AM
                                MSI Creator Z16 HX STUDIO B13VGTO-051 Notebook Z16 HX Studio Specification for Upgrade or Repair
                                This specification for the MSI Creator Z16 HX STUDIO B13VGTO-051 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z16 HX STUDIO B13VGTO-051 boardview and Z16 HX STUDIO B13VGTO-051 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
