CD player Technics SL-PG490 (SL-PG490E-K) repair, CDM12.1 (VAM1201) "no disc" (fixed)
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    This was supposed to be a routine pickup replacement, as it had already been cleaned a few months ago and now it's not dirty (neither outside nor inside prism/mirror). It throws a "NO DISC" message with very little tries. It uses a Philips CDM12.1 mechanism, also known as VAM1201.
    Some time ago I ordered 5 pickups from AliExpress (shivers). As they came without mechanism, the price was good (this is the common part of all AliExpress stuff) and pictures looked decent. They arrived promptly and as described but couldn't try any, because I didn't have any pending repair requiring this pickup. I left positive feedback.
    Today I use the first one with this Technics and... it doesn't even do focus movement, I mean, the simple act of moving the lens up and down trying to focus the disc surface. This is something that even a pickup with dead laser or sensor does, because the driver tries to focus even if nothing is received from laser sensor.
    I disassemble the pickup again and check the coils continuity. The Tracking coil is OK (about 18Ω) but the Focus coil is open. Upon visual inspection I detect that the flexible wire is cut at the point shown in picture!! (picture is NOT actual pickup but the original one, I won't disassemble again just to take a picture, sorry). Pickup looks new, not refurbished, but this defect is quite revealing. Other wires seem tight. From left to right, Tracking coil is at wires 1 and 4, while Focus coil is at 2 and 3.
    I decide to solder the loose wire, although I can see that these wires are not "soldered", but twisted around a pin and then seems that they melt the copper with some high voltage discharge (?). I don't understand why they have to do it this way, it has to be some reason. I've soldered wire to its pin and now everything works fine. For how long?
  • Longbow
    • Jun 2011
    • 623
    Re: CD player Technics SL-PG490 (SL-PG490E-K) repair, CDM12.1 (VAM1201) "no disc" (fi
    Because of heat. It is like soldering a thermal fuse.
    Is it plugged in?
    • Chungalin
      • Jul 2014
      • 423
      • Spain
      But these aren’t fusable wires. They just need to be very flexible to stand the lens assembly oscillation as it tracks CD surface as it spins. In this sense, they’re similar to speaker wick cables that go from the contact tab to the cone.
      And, apparently, nothing bad has happened when I’ve soldered it as any cable.
      • Chungalin
        • Jul 2014
        • 423
        • Spain
        I’ve just repaired another CDM12.1 / VAM1201 mechanism from a Philips CD163/00 CD player. In this case, tracking coil was open (2 outer wires). I’ve soldered the cut wire to the pole, trying to use as few solder as possible. It works!
        BTW, no return from the other repair.
        • nervous_capybara
          Repairing the Hitachi DA-6000 CD player
          by nervous_capybara
          Hello everyone !
          I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
          Feel free to share your experience if you ran into other issues.
          DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
          CD tray would not come out of the player
          I could hear a motor spinning inside the player but the CD tray would not come out.
          Turned out that the issue was the CD tray belt that aged poorly and began to...
          11-05-2025, 03:11 AM
        • Junior††
          PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
          by Junior††
          Good Afternoon fellas,
          Issue:
          Disc is showing as not supported when a disc is put in.
          Here's what I've done, you can skip this if you just wanna know the question:
          - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
          - reflowed the disc drive connector
          -reflowed the chip in question (shown on image)
          - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
          Question:
          I...
          02-19-2025, 12:48 PM
          MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
          This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
          09-06-2024, 05:30 PM
        • dkneyle
          Onkyo DX-V500 Laser Disc Player - weird SMPS fault
          by dkneyle
          This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
          Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
          02-01-2022, 02:08 AM
        • ahmedtou
          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
          by ahmedtou
          help me please
          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
          I will share all the details with you, including the disc information.
          Code:
          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
          Current Profile: BD-R
          Disc Information:
          Status: Empty
          State of Last Session: Empty
          Erasable: No
          Free Sectors: 12,219,392
          Free Space: 25,025,314,816 bytes
          Free Time: 2715:27:17 (MM:SS:FF)
          Next
          08-27-2025, 08:49 AM
