Mitsubishi DA-U31 amplifier repair, no sound (fixed)
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    This old good amp with 2SA1103 / 2SC2578 pairs had no sound at all. No relay click. There're ±47V OK. Seemed like a protection, but not clearly stated.
    I check power transistors output and at one channel there's high DC, so yes, it's a protection.
    No transistors shorted. In this case, Q301 solders are clearly broken due to long term thermal expansion/contraction. It has a long aluminium heatsink, and Q301 and Q401 are at both ends, so they suffer from dilatation differences between heatsink (where they're screwed) and PCB (where they're soldered). This is the A-B-C of vintage amp repair.
    Ressolder Q301, Q401, IC301 and IC401 (preamp ICs). That's all.
    Amazingly powerful, great bass.
  • ChaosLegionnaire
    by ChaosLegionnaire
    09-13-2022, 09:02 AM
  • UserXP
    Mackie CR4 amplifier no sound
    by UserXP
    Hi, people.
    I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
    Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
    10-17-2020, 05:06 PM
  • eduaqa
    Amplifier - bad sound when loud sound on bass
    by eduaqa
    I'n trying to fix a M&S SYSTEM DMC-1which have following problem:
    I'm using FM station to do this fix, I works perfect if volume below around 8 or if bass is set to zero, the sound can go to 20 without problem, but if I set bass to maximum and try to go over 10 the sound comes distorted ... I saw a video on YouTube the person saying about the main capacitors on the power portion, but I disconnect the main transformer and inject direct to the capacitors PINs my bench power supply -23v 0v +23v, but still distorted so I think the problem is not the capacitor neither the transformer...
    08-06-2022, 11:28 AM
  • Francesc V.
    Tele-master AS-20 amplifier. No output sound, just noise
    by Francesc V.
    Hi:
    I bought this amplifier from the 70s to try to repair it. So far it has no output sound, just noise. You can volume it up and down.
    I've checked fuses and all are ok.
    I've continued with capacitors:
    • The main black one should have 4700uF, but it has lost half of its capacity during these years.
    • The ones that I've numbered have still a really low ESR and the full capacity after ¿40 years?
    The 4 transitors are perfect. Desoldered and tested individually.
    There are also components which I don't know exactly what they are....
    02-16-2023, 07:55 AM
  • i_am_patch
    Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
    by i_am_patch
    Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
    04-30-2024, 08:20 PM
