Yamaha RX-A720
  • ned1
    • Feb 2014
    • 139
    • usa
    Yamaha RX-A720
    Have problem with constant sound cutting off. Upgraded firmware no change. It appears to cut sound on any device connected to it with HDMI or Optical.
  • charis
    • Mar 2016
    • 61
    • greece
    Re: Yamaha RX-A720
    Look i fix an RX-V1500 the problem was dc on output.When you push the speaker A-B was putting a noise and the volume goes down.
    the problem was the 5,2v on C586 C587 the R644 D503,D504,D505 and on R650 on pin 139 of the CPU ic520.(control of relays)
    Also if the relays open close (after first load) i know that i have cold joint especially on the output connectors.
    Keep in mind that the volume control on this units are very sensitive on dust also the hdmi cables on this reciever use a return audio path to monitor the sound so check cables also or use the AV output.
    Next suspect is the preamp voltages and the HDMI circuit.
    Also sometimes the problem is from main power rail 2 polyesteric capasitors but then you have also display problems.
    The good news is that the unit dont go to protect mode.
    • ned1
      • Feb 2014
      • 139
      • usa
      Re: Yamaha RX-A720
      Thank you for your reply. This Yamaha does not have A/B speaker button on front or on the remote. The problem with this one is sounds comes on few seconds and off few seconds. It appears to be with any input.
      • charis
        • Mar 2016
        • 61
        • greece
        Re: Yamaha RX-A720
        Ok.
        First start by cleaning the switches and the volume control.
        After that check all the ribbon cables to have good contact.
        Then check if the output to speaker terminals is steady if not resolder them and cleaned.
        Try a spare cable to speakers.
        Make a visual inspection and take photos.See if you smell something or you have discoloration at any part and pcb.
        Now try all the channels if have output(and the surrounds).
        Next step check if you have good sound on headphones jack.
        Reset the unit or go to previous software(or update).
        Try to use a spare speaker to test the output channels.
        If you do all this you complete the first part of troubleshoting.
        • Longbow
          • Jun 2011
          • 623
          Re: Yamaha RX-A720
          We are jumping ahead too quickly.
          Does this mean speaker outputs? Is the unit intermittent on preamp out?
          Well, if you are fine with a line-level analog audio input, then we don't have an amplifier problem. Maybe you could be more specific before diving into the firmware or looking for burned or shorted components.
          Is it plugged in?
          • ned1
            • Feb 2014
            • 139
            • usa
            Re: Yamaha RX-A720
            http://www.avsforum.com/forum/attach...chmentid=63678
            Please check the link above. It's exact problem I have. It has problem decoding the signal. While watching the screen from link above all inputs in the right side will disappear while sound is gone and all output speakers will turn off ( white color) when sound cuts off. When sound is ok you get all output speakers color turn yellow and inputs on the right side shows up.
            • ned1
              • Feb 2014
              • 139
              • usa
              Re: Yamaha RX-A720
              To be more clear when no sound the input format wil show ---- instead of digital and same for channels, sampling, bitrate it change to -----
              • Longbow
                • Jun 2011
                • 623
                Re: Yamaha RX-A720
                From your problem description, nobody would have come up with a Dolby decoder malfunction. How about starting with what actually DOES work, to eliminate all the usual suspects?
                The link says "broadcast Dolby". Is that correct? Are we dealing with the usual problems associated with low signal level? When the display switches over to a blank -------, it indicates that there is nothing to decode, or the level is too low to detect. One idea would be to switch to a known good Dolby source and note the results.
                Is it plugged in?
                • jjne
                  Yamaha RX V675 sound issues
                  by jjne
                  I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
                  From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
                  At first I thought it was either a speaker relay or the DSP, but I don't think...
                  06-24-2025, 07:01 AM
                • AlexVG
                  YAMAHA CLP-550 without of sound
                  by AlexVG
                  Hi.
                  I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
                  I have replaced all green marked elements, but it gave me nothing.
                  The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
                  But it is custom YAMAHA's chip, and I can't find any information about it.
                  Maybe somebody came across with the same issue?
                  Any information will be very useful. I will be very appreciated.
                  Thank you....
                  06-08-2025, 09:29 AM
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
                • maleksa
                  Yamaha MOX8 boot freeze and distorted sound
                  by maleksa
                  My Yamaha MOX8 synthesizer recently developed two issues.
                  Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
                  Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
                  11-07-2024, 03:28 AM
                • daigs
                  Yamaha P-115 turn on but No sound - Doesn't turn off
                  by daigs
                  I need to repair a P-115 yamaha digital piano with a strange behaviour.
                  When I power on the piano from the dedicated on/off switch, the power led go to ON (red led), but the keyboard doesn't produce any sound, nor in the speakers nor in the headphones.
                  When I try to power off (pressing the switch for at least 1 second), the keyboard doesn't power off, the red led remains ON. I need to unplug the adapter cable to switch off the keyboard.
                  I checked the 12V voltage rail on the input PCB, after the power plug and it is OK.
                  I checked also the...
                  07-18-2023, 03:47 PM
