onkyo ht-r990
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: onkyo ht-r990
    Oh, good, so it's as i first suspected - just making sure Usually voltage readings are taken with respect to (at least) the circuit ground, that's why we "need" the + and -.
    Have you checked for DC on the amplifier outputs, as indicated in post #8?
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • harleyman58
      • Feb 2016
      • 89
      • usa
      Re: onkyo ht-r990
      ok there is a place on top of the board where I can check the prot. if I ground the black to chassis and the red to vprot I get 137 mv,red to iprot 138,red to volh -1.9. there is a point called hpground black to it red to vprot 134 mv, red to iprot 134 red to volh -4.9 .
      • harleyman58
        • Feb 2016
        • 89
        • usa
        Re: onkyo ht-r990
        there are also these points to check, sprlz2,sprlcs,sbz2m,amu,sec1h,sec1 off.
        • harleyman58
          • Feb 2016
          • 89
          • usa
          Re: onkyo ht-r990
          isn't all this controlled on page 8 by q701? there is no output on jl600a on any pins.
          • Khron
            • Sep 2006
            • 1350
            • Finland
            Re: onkyo ht-r990
            What exactly does "no output on JL600A pins" mean?
            Let's take this another way - what audio sources do you have available for testing, apart from HDMI?
            • harleyman58
              • Feb 2016
              • 89
              • usa
              #26
              Re: onkyo ht-r990
              well the radio doesn't work, the headphones don't work , what do you want me to check?
              you ask me to check the output signal on jl600a/b on post #8, I don't get any mv reading from c to ground and the same for l,r,sl,sr,sbl,sbr.
              • Khron
                • Sep 2006
                • 1350
                • Finland
                #27
                Re: onkyo ht-r990
                Sources, as in INPUTS; headphones are outputs.
                Nothing at all, you say? That's a bit odd, i'd expect at least SOME mV to be present - it's a bit unlikely all the amps are THAT perfectly DC-balanced...
                Could you check the voltages, referenced to pin 3 of each amp chip, on each of the RE pins? Ie. pins 4-5-6-7 on Q6002/6003, and pins 4-5-6-7 and 17-18 on Q6001
                • harleyman58
                  • Feb 2016
                  • 89
                  • usa
                  #28
                  Re: onkyo ht-r990
                  ok 6001 with the black on pin 3, red on pin 4 =3.2mv, pin 5= -4.1mv,pin 6= -0.9, pin 7= 6.2 mv.,pin 17= 2.0 mv, pin 18= -5.3 mv.
                  ok 6002 with the black on pin 3, red on pin 4=2.6 mv, pin 5= -6.5 mv,pin 6= -8.9 mv,pin 7= 0.8 mv.
                  ok 6003 with the black on pin 3, red on pin 4=4.5 mv, pin 5= -4.0, pin 6= -8.8 mv, pin 7= 0.3 mv.
                  • CDNBrewer
                    Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                    by CDNBrewer
                    Hello Everyone,
                    I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                    Symptoms:
                    • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                    • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                    • I swapped the Left and Right surround
                    08-05-2025, 09:29 PM
                  • ugamazing
                    Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                    by ugamazing
                    I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                    08-31-2022, 07:34 AM
                  • ai.need.help
                    Onkyo TX-8050 AV-Receiver no sound
                    by ai.need.help
                    I have a problem with my Onkyo TX-8050 Receiver. I got it from aftermarket and it was just delivered today.
                    It doesn't play music. There is no real output from:
                    pre-out
                    amp-out A and B
                    phones out
                    The only real sound I hear is a humming from the speakers when I play a song from usb or select a analog source. And when stopping and starting songs from usb or switching sources, I hear a crack from the speakers.
                    I tested with analog-input, usb and radio.
                    I know that there is a common problem with...
                    12-20-2022, 05:54 PM
                  • benspawn02
                    Anthem MRX500 - no sound. R2A15218FP issue??
                    by benspawn02
                    Dear Electronics Experts:
                    I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
                    08-12-2023, 04:46 AM
                  • redbaron1007
                    Onkyo HT-R510 turns on and then immediatly off
                    by redbaron1007
                    I picked up an Onkyo HT-R510 that when I plug it in and press the power button will turn on and then a couple of seconds later turn itself off. When it turns on you can hear the relay click and then immediately click again and shut the power to the system off. I spent about 5 hours today trying to troubleshoot it and I did make some progress that may not actually tell me anything. It's still not really working and I'm not quite sure where to go next.
                    Here's everything I've done so far.
                    The first thing I did was open it up and check for any burn marks exploded parts...
                    11-14-2021, 09:55 PM
