Sherbourn 2-100A Amplifier
  • edbog
    • Apr 2009
    • 21
    Would anyone have a schematic of the innards for this amplifier? Trying to repair one-thanks.
  • edbog
    • Apr 2009
    • 21
    Re: Sherbourn 2-100A Amplifier
    Since posting the above message, I have taken the amplifier apart and have the main board by itself but I don't know how to attach a picture of it so when I ask a question I can refer to it. Would much appreciate directions because there is a lot I don't know. The pictures are now on the desktop.
      • 30997
      click on "post reply"
      type your message.
      scroll down to "manage attachements" and click on it.
      then choose the files and click "upload"
      • edbog
        • Apr 2009
        • 21
        stj:
        I followed your instructions. The file(1.31 MB) is in Current Attachments but nothing happens after that. I thought the picture would come up on the message but nothing. If I click on the title of the attachment, I can transfer it as an URL to the message. I want to show the actual picture. The only other thing I can do with the file that's in Current Attachments is Remove it. There is no Upload from the Current Attachments. So that's where I am now.
        • edbog
          • Apr 2009
          • 21
          Oops, there it is. But now, how would I have it in the right position?
          Thank you for your help.
            Can you read the P/N of those components that are attached to the heatsinks?
            What is it not doing any way?
            Also should take straight shot pictures of the top and bottom sides of the board.
            • edbog
              • Apr 2009
              • 21
              budm:I think my turning the amp. on and off a number of times while using it when I was repairing the two AR 2ax speakers that I have may have caused this problem. The amp. stopped working. The on light wouldn't come on and it blew fuses. Sent it to company that bought out Sherbourn and this seems to be the problem: The output drive IC and both output transistors have blown plus the power switch has to be rebuilt. So I decided to fix it myself but I need lots of help because I can't do it myself and all help would be greatly appreciated to get this novice through it.
              budm, I'm not sure but do you want an overheard photo of the card and two sides so you can see the transistors? If not I don't know what you mean by the bottom.
              Anyway, I'm sending the overhead now. The front is where the two large caps(6800 mfs)are. Behind them are what I think are relays for each channel.
              Starting from front to back there are three pairs of transistors. The first pair, the ones closest to the large caps are: MOSPEC 2SB817E, HO7B the second pair are: MOSPEC 2SD1047E, HD6B, the last pair, the ones closest to the back are:TDA7296 388 D20230. This pair has 8/7 terminals whereas the first two have three. I have researched these and I think I have substitutes for these pending confirmation and input from the Forum members.
              The three prong terminal at the front lower left connect to the secondary of the transformer. With the two large caps you can see some semisoft plastic material in between them. I assume this is to keep the two caps stationary and connected to each other and nothing to do with its' function nor is it seepage.
              Here is the top view.
              • edbog
                • Apr 2009
                • 21
                I hope this is the top view
                • edbog
                  • Apr 2009
                  • 21
                  Another try
                  • edbog
                    • Apr 2009
                    • 21
                    I forgot to add, the caps all look good, no bulging or leakage. Except for the large two caps, there is a small amount of hard(dry) light brown material around the bottom. I don't know if this is leakage around the bottom or something that helps its' functioning.
                      OK, you go the picture of the top side of the board, now we need the bottom side of the board so we can see the traces of the board.
                      You should also check the resistance between the Collector and the Emitter of those four big transistors (2SB817E, 2SD1047E) to see if they have low resistance.
                      • edbog
                        • Apr 2009
                        • 21
                        More pictures.
                        • edbog
                          • Apr 2009
                          • 21
                          Closer look at caps.
                          • edbog
                            • Apr 2009
                            • 21
                            Closer look
                            • edbog
                              • Apr 2009
                              • 21
                              Here is the underside.
                              • edbog
                                • Apr 2009
                                • 21
                                Checked the two large transistors.
                                From the front the left set: #1 only shows OL and no beeping between C & E;
                                The same when connecting C & B; But when connect B & E, there is beeping and 0.7 ohms. The same result when testing transistor #2 on left side.
                                On the right side:
                                #1 shows 0.4 ohms and beeping when connecting C & E; The same when connecting C & B; The same when connecting B & E. With #2 transistor on right side everything is the same as in #1.
                                There may be too much information here but it seems the two transistors on the left side are not working. Then, what caused them to fail?
                                I don't know enough to say the set on the right side is working but if i'm going to change left side might as well change right side.
                                  On the right side:
                                  It does look like you do have shorted out output transistors, you should remove them and verify them again off the board.
                                  They may have failed due to overload or shorted load (speaker wiring, speaker, etc.), parts do fail, or just poor circuit design.
                                  • edbog
                                    • Apr 2009
                                    • 21
                                    Thanks will do but have to get one of those solder suckers.
                                    But, what about the two TDAs. Could they have been shorted also?
                                      "But, what about the two TDAs. Could they have been shorted also?"
                                      Have to download the spec for the TDA to see.
                                      • edbog
                                        • Apr 2009
                                        • 21
                                        Here is one spec sheet.
                                        http://www.datasheets360.com/part/de...FY0XHwodY7EAKw
                                        What do you look for to determine if good or bad?
                                        The output drive IC is also burned out. Where is it on the board? Is it one thing or consists of a number of parts that can be changed? It must be different from the 2SB817 & 2SD1047?
                                        • MrCommunistGen
                                          Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                                          by MrCommunistGen
                                          My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                                          I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                                          07-12-2021, 05:11 PM
                                        • jinu_j
                                          How to test Subwoofer Amplifier with only a multimeter
                                          by jinu_j
                                          Hi Folks
                                          Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                                          Problem
                                          I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                                          Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                                          Any advice would be appreciated...
                                          08-29-2024, 02:05 AM
                                        • UserXP
                                          Mackie CR4 amplifier no sound
                                          by UserXP
                                          Hi, people.
                                          I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
                                          Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
                                          10-17-2020, 05:06 PM
                                        • Francesc V.
                                          Rotel RSX-1056 amplifier. Troubleshoot a noisy channel
                                          by Francesc V.
                                          Hi:
                                          I've realized that one of the channels of this amplifier has no proper sound.
                                          This is the signal at the speakers output.
                                          As long as the audio coming in to the amplifier board (blue) looks ok although with some noise due to the wire, I think that there's nothing to look at the preamp section.
                                          Now, I could start looking at components to see whether I find the guilty one.......but I would rather prefer to ask for advice. Here there is the amp. schema. Which points would you check with the oscilloscope to gather...
                                          07-15-2025, 01:33 AM
                                        • waspie
                                          Aiwa GX-770 Amplifier Protection Circuit
                                          by waspie
                                          I am by no means an expert on this type of troubleshooting but I can follow direction real well.
                                          I'm no stranger to using a meter and soldering iron so I'm looking for some help in fixing an old amplifier/system I got. This is part of a system "V-1200" by Aiwa where there are several components. My first problem seems to be the amplifier.
                                          It seems to be in protection. When first turned on I hear the inital relay coming on but never the second relay which is connected to the protection IC. I don't see any obvious bad components on the board. If I ground the...
                                          11-29-2022, 09:58 AM
