Onkyo TX-NR626 & TX-NR636 Resistor Question
  • dolivas27
    • Mar 2014
    • 66
    I have a question on replacement resistor in Onkyo receivers.
    The Service Manual call for this
    R6073 NON-FLAMMABLE CARBON FILM RESISTOR R25J-120
    I am having a hard time finding a flameproof carbon film resistor I need several values can I use a metal film in place of the carbon film.
    If not any suggestion on a source for the flameproof carbon film?
    Thanks for the help.
  • redwire
    • Dec 2010
    • 3912
    Re: Onkyo TX-NR626 & TX-NR636 Resistor Question
    What part of the circuit uses the resistor? The only thing special about carbon film is it can take massive overloads for short periods. Oh, and they make a lot of smoke and fire when they burn...
    I've never seen flameproof carbon resistors, it's probably a typo in the manual. I see that a lot- fusible, flame-proof, metal film, carbon film mixed up in translation.
    I would use a flameproof metal-film, or fusible if it's safety related.
    • dolivas27
      • Mar 2014
      • 66
      These are in the pre-amplifier & amp section.
      The do look like they could be carbon film.
      I will be selling the unit once repaired and I want them to be right.
      I have the service manual if you would like to look at it.
      • redwire
        • Dec 2010
        • 3912
        I believe metal film are better in almost every spec except for surge power handling. Some audiophiles prefer their (carbon) vintage sound.
        Metal film resistors have better:
        Lower Noise
        Long term stability
        Temp coefficient
        Resistance tolerance
        PM me the service manual and I will check why these are spec'd.
        • dolivas27
          • Mar 2014
          • 66
          Lower Noise
          Long term stability
          Temp coefficient
          PM sent Thanks
          • commpradeep
            • Aug 2015
            Can you please share service manual if it's available. I'm trying to fix my receiver myself but could not find the manual
            • jinu_j
              by jinu_j
              Hi
              05-03-2025, 10:51 PM
            • mikey5791
              by mikey5791
              Hi to all forum members,
              12-26-2024, 04:55 AM
            • MidnightRoller
              Can a resistor lose resistance after hot air?
              by MidnightRoller
              I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
              I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
              02-02-2022, 11:46 PM
            • artvandalai
              What resistor ohm will work better to repair this waterpik?
              by artvandalai
              The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
              01-05-2025, 04:10 PM
            • chth96
              Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
              by chth96
              I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
              Since then, This AC/DC adaptor have been out of order.
              But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
              After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
              And Is there any possibility that it will suddenly explode as well as to be out...
              12-03-2023, 04:40 AM
