Re: Onkyo TX-NR636 transistors
I can't vouch for the pinout, but would something like a BD140 be a suitable replacement for the TTA004B? Vceo might be a bit low, though. MJE350 has higher voltage but lower current ratings.
With regards to the other ones, there should be plenty of (low-noise) european (BCxxx) or japanese (2Sxxxx) that might be suitable, i'd figure.
I'm trying to find these transistor and I can't find them.
Any help, would be appreciated.
- TTA004B(marking is A004B)
http://www.datasheets360.com/part/de...2860135996629/
- BF81W
- BE96W
These are in the pre-amp section.Tags: None
by Francesc V.Hi:
I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...-
by GCMI would like to find out where I can buy the above mentioned board
Any help will be highly appreciated-
06-30-2022, 01:21 PM -
by FrancescoVGood morning everyone,
I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
The firmware reported is the following:
M:1.00/11107BLP
D:?.??/????????
O:1.00/11107AL
The DSP firmware given the question marks seems corrupt.
On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...-
05-11-2025, 02:59 AM -
by redbaron1007I had a Sundown SFB-8000D amp come into the shop yesterday that wasn't giving any output. The guy who brought it in said he bought it off some crack head on Facebook marketplace for a good price, but bought it knowing it was broken. Apparently the original owner was cutting out the transistors to the right of the ones pictured whenever one would blow and take the output out. Best I can figure he also cut the legs on the S5 and S6 ic's as well and soldered them back together.
My problem is Sundown decided in the factory to remove the original markings on the IC's and now I can't figure...-
by Bob WongWelcome badcaps, repairing a Crosshair 15, in need of transistor specifics. Received a broken laptop that's was perfect for repair, threw away the looser transistors in a haste... Should and could have salvaged them.
In any case, I will be posting all my discoveries to this forum as a thanks in advance. Thanks in advance lol.
P.S. If anyone is familiar with such things, as in, If anyone knows that MSI uses one or one of a few types of transistors when marked with a number please let me know how I can find more specifics before I start throwing hail marys. - Loading...
