Sony playback problems
  • pentium
    • Mar 2006
    • 2778
    After my uncle passed away, one of the many items I received was his trusty Sony TC-377 reel-to-reel deck and about a four foot tall stack of tapes.
    Today I finally got the time to pull it out and try it and after figuring out what each knob did I hooked up my cd player, grabbed a blank reel of tape and did a test recording using Gershon Kingsley's Music to moog by CD.
    When the cd ended I rewound the tape, re-threaded it and turned the knob to play.
    Almost as soon as the music started to play I noticed that it was playing back slower than normal. I then also noticed that the right channel was silent.
    First thing I did was remove the reel, clean the heads and record a 20 second clip I knew was stereo. When I played it back it was still slow but the right channel was STILL silent.
    I switched off the left channel and cranked up the amp to hear if anything was coming from the right. It was faint, but it was there...Or I was just getting stray noise from the left.
    Then my amp overloaded and kicked out. I forgot that there was a leakage problem and going too high would kick the amp out and reset itself (I need to retune the radio).
    Anyways, excluding the amp issues, What's going on?
    I don't dare want to open the player up due to all the mechanical parts inside just screaming to be knocked out of adjustment and visually the heads look okay.
    Find Nedry!
    Check the Vending machines!!
  • pentium
    • Mar 2006
    • 2778
    Re: Sony playback problems
    Oh, I forgot to mention that this thing has probably not seen a good oiling in a few years and it came from the room of a smoker however it was covered by a white cloth (which was yellow when I got it)
    Find Nedry!
    • pentium
      • Mar 2006
      • 2778
      Okay, it plays back at normal speed if you DON'T HAVE THE PAUSE BRAKE HALF-ENGAGED.
      So that just leaves the tape head(s).
      This is a tri-head system. One records, one is playback and the third erases?
      My uncle was an audiophile. He used only the best.
      Find Nedry!
      • pentium
        • Mar 2006
        • 2778
        Oh heck, I suck at troubleshooting.
        The right channel monitor switch had corroded contacts. Cleaning them restored the right channel.
        Problems solved.
        Find Nedry!
        • Maxxarcade
          • Jul 2006
          • 973
          I've got an old beat up Sony TC-200 that has a flakey Line/Speaker output select switch, and both volume pots are shot. Problem is I can't get it apart without a ton of work.
          Anyone know how to align the heads on these things? There is only a couple adjustments, but I know they are off.
          • pentium
            • Mar 2006
            • 2778
            My goodness.
            Along with the TC-377 there was also a TC-200 in the closet along with it's manual and plastic cover.
            How hard is it to align a head?
            When it comes to complex stuff like that just take many photographs.
            That saved me alot of trouble when I had to replace the carriage clutch spring on my selectric typewriter. That thing has more moving parts than a wind-up clock!
            Find Nedry!
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              have you tried to get some deoxit into thse parts yet?
              i have fixed pots that nothing else would clean up.
              btw i have a ton of sony service manuals here.
              if i can find the ones you need i can scan them for you.
              • goodpsusearch
                Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
                by goodpsusearch
                Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
                First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...
                05-05-2024, 02:04 PM
              • Carlos#2003%
                Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                by Carlos#2003%
                Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                02-15-2024, 07:52 PM
              • dkneyle
                Sony KDL-46HX850 Can't upgrade/update firmware
                by dkneyle
                Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                09-25-2024, 10:44 PM
                Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 05:27 AM
                Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                09-06-2024, 05:30 AM
