pioneer xdj rx locked
  • falcontech
    • Oct 2013
    • 484
    • italy
    Hello
    xdj rx1, it turns on normally, the internal software starts with the classic Pioneer screen, the decks window appears, but the system is completely frozen, all the buttons are unresponsive, the USB ports don't work. I tried connecting it to the PC via USB, and it's visible to both the computer and the software, but I can't authorize it to work because the MIDI button on the controller doesn't work. The right deck remains with the center LEDs lit, as if it's not completing the boot process. Any suggestions?​
  • madan1
    • Nov 2016
    • 726
    • Bulgaria
    Check for bad caps on the power rails. Excessive ripples might cause the microcontrollers to freeze.
    • falcontech
      • Oct 2013
      • 484
      • italy
      Do you mean the power supply or in general? Because the problem could be anywhere, the controller is divided into various sections with different boards and there are quite a few capacitors... I have the service manual in case it could be useful.
      • CapLeaker
        Leaking Member
        • 8339
        If it is a cap issue, warm that thing up with a hair dryer no more so you can’t touch it.
        To me it sounds like a different issue. More like I2C between couple of chip direct communication not working, kernel panic or something along that line. It either crashed, or it is waiting for a different chip to communicate and thus never finishes. Maybe you find some serial or a TTL output to hook up a terminal to and see what happens when you boot.
        • falcontech
          • Oct 2013
          • 484
          • italy
          I'm attaching a video so you can better understand the problem.
          • CapLeaker
            Leaking Member
            • 8339
            Can you do a firmware upgrade or a hard / full reset?
            • lotas
              • Jan 2016
              • 4783
              • Russia
              Try:
              • To reset the Pioneer DJ XDJ-RR to factory default:
                1. Press and hold the DECK 1 DELETE button and the DECK 1 TEMPO RANGE button at the same time.
                2. While still holding the buttons, press the Power On switch to turn on the unit.
                3. Continue to hold the power switch until the unit starts up completely.
              • falcontech
                • Oct 2013
                • 484
                • italy
                no it won't let me do it because of the blocked keys, same goes for the reset
                • falcontech
                  • Oct 2013
                  • 484
                  • italy
                  Originally posted by lotas
                  Try:
                  no it won't let me do it because of the locked keys
                  • CapLeaker
                    Leaking Member
                    • 8339
                    Is rekordbox maybe in EXPORT mode? That will also disable all buttons.
                    • falcontech
                      • Oct 2013
                      • 484
                      • italy
                      but the controller is not connected to the PC, so rekordbox is not present
                      • falcontech
                        • Oct 2013
                        • 484
                        • italy
                        I borrowed an identical controller and tried swapping the top panel (deck1, mixer, deck2) and it turned out that the problem is in the main assembly. Any suggestions? I can send some photos.
                        • Bushcat
                          Pioneer PL-X9 motor speed control wobble
                          by Bushcat
                          I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
                          Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
                          BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
                          05-24-2023, 03:36 AM
                        • lallollas
                          Acer chromeBook c733-c3uy Locked need help
                          by lallollas
                          chromebook locked without google account i alreadu edit rom and change value enrol 1 to 0 and still locked need help
                          model n18q5...
                          04-09-2024, 08:14 AM
                        • EduCabral
                          [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
                          by EduCabral
                          I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
                          While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
                          🔧 Details:
                          • Model: YT-M06
                          • Interface: Pioneer 1
                          • MCU: Fujitsu MB89F202
                          • Goal: Find a valid .bin firmware file or memory dump from a working unit
                          I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
                          07-15-2025, 12:26 AM
                        • pixelcap
                          Pioneer Kuro Pro 111FD 8 red blink error
                          by pixelcap
                          Pioneer Kuro Pro 111FD 8 blink red LED.
                          I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
                          So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
                          based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
                          10-06-2024, 11:26 PM
                        • RatherLoopy
                          Pioneer VSX-44 receiver HDMI dropouts
                          by RatherLoopy
                          I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                          I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                          And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                          05-26-2023, 03:54 PM
