Yamaha AX-750 no sound
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    Another thread to document this repair.
    Yamaha AX-750, comes with no sound, no relays activate (it has 3). One channel is working, because heatsink gets warm. Not the other, it's cool. No power led on, neither the Pure Direct led, but the led on Volume knob is blinking. User manual says this indicates Muting (-20dB). Remote control doesn't do anything.
    Inspection: [Q624] with broken solders and "-15V" are really -20V, not good. "+15V" are +15V, OK.
    I resolder [Q624] and some other transistors near there. Now both channels are working (both heatsinks warming), but still the same problem, no relays, no sound.
    I replace 16V zener diode [D617] that regulates -15V. Fixed this, now really -15V. But the problem doesn't go away.
    I found some broken solders on the long bridge PCB (MAIN3 in schematics, [12-3] in exploded view), resolder everything but no change.
    Days later I find that signal POFF is almost zero and should be -19V. It comes from the transformer (+-20V) after rectifying half wave. Then I notice that resistor [R720] is open (1Ω). Replace and voila!
    The only problem remaining is inoperative remote control and persisting Mute. It stays in Mute mode (blinking led in volume know), so the only way to hear it is activating Pure Direct or raising the volume a lot. The remote control is OK, it emits signal, and the IR signal gets to pin 27 of microprocessor and it "looks" good at the Scope.
    Well, the customer didn't ask that much, as he already knew that the remote wasn't working 10 years ago. The short solution: desolder pin 38 of microprocessor, disabling the user Audio Mute signal. There's another Mute signal for functional purposes, not user, and that is working fine.
  • jjne
    Yamaha RX V675 sound issues
    by jjne
    I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
    From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
    At first I thought it was either a speaker relay or the DSP, but I don't think...
    06-24-2025, 07:01 AM
  • AlexVG
    YAMAHA CLP-550 without of sound
    by AlexVG
    Hi.
    I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
    I have replaced all green marked elements, but it gave me nothing.
    The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
    But it is custom YAMAHA's chip, and I can't find any information about it.
    Maybe somebody came across with the same issue?
    Any information will be very useful. I will be very appreciated.
    Thank you....
    06-08-2025, 09:29 AM
  • ChaosLegionnaire
    by ChaosLegionnaire
    09-13-2022, 09:02 AM
  • hemant_2222
    Yamaha 2064 No sound but Test audio working
    by hemant_2222
    Hello Guys,
    Greetings!
    Hope you all are doing well.
    I am looking for suggestion on Yamaha 2064. The problem with this receiver is that it has no sound however when the test tones are activated it does outputs from all the speakers. It is working in two channel stereo mode but when you select other sound modes, it doesn't. The last time it had a problem, I had replaced the DAC
    PCM1681DBQR - IC263 and it worked fine.
    Other issue with it is one of the STK ICs is getting more heated then the other one but that can be looked at later.
    11-01-2025, 11:20 PM
  • maleksa
    Yamaha MOX8 boot freeze and distorted sound
    by maleksa
    My Yamaha MOX8 synthesizer recently developed two issues.
    Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
    Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
    11-07-2024, 03:28 AM
