I have this amp and it was working fine. Was using it and the sound went out after a relay click and the "fl off" light started to flash. I unplugged it for a couple of hours and plugged it back in and the light just blinks, nothing when you press the power button. Checked the voltages from the main power board and I am getting 5.65 out of the 3 pins that are supposed to be 5.5v. I have unplugged the amp board and all other boards, still the "fl light" just flashes.
Pioneer VSX-1021k
Re: Pioneer VSX-1021k
Get the service manual from here:
http://elektrotanya.com
You will have to wait, like 30 seconds and then the Get Manual will appear below the picture.Comment
by flat-eartherThe charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
Windows also shows ''Plugged in'' when charger is not connected.
This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
If I let battery run out and say it has 3% Windows will... -
by GraphicManHello guys
Because the unit is old (but only occasionally used) the loudness button causes some noise due to bad contact,
sprays did not work, so i decided to solder the pins that it connects on the pcb at the on (loudness on) position
i did that and it worked fine, i know from the bottom of my heart that the switch connects 2 pins and also d/c other 2 pins
on every position it have (6 pin switch), so i was curious what would happen if i clicked the switch off while the pins are soldered at on (so basiclly on and off at the same time), when i did so the sound is gone, nothing...-
by sam_sam_samI have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
I also have back when Light of America had these light bulbs available for yard lights
The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
While the Lithonia lighting fixture has all most certain bulb failure
So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
I have only had this light fixture for not more than a year if it... -
by Phil StasikPioneer Pro-FHD1 Elite. Failure to power on.
I'm new to this awesome forum, and have been reading like mad, but have not seen the answer to my challenge.
We bought this Panasonic plasma monitor 16 years ago and it has never been serviced, so all parts are original, and the unit has never malfunctioned -- until about a month ago. The system fails to power on. At first (a month ago) this happened rarely. We learned to unplug for a few minutes to drain the caps, then re-plug, and the monitor would start normally. Now, we plug-in, turn on the main power switch, and the... -
This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 03:40 AM
- Loading...
