yamaha rx-v571 firmware, anyone?
  • gerenis
    • Mar 2025
    • Hungary
    Anyone got the firmware for yamaha rx-v571? Not available on the internet.
    I've got a defective RX-V571. Could be due to a failed update, but the only function I can invoke is "USB UPDATE".
    Normal power on, Diagnostic mode or Protection Cancel mode don't work.​
  • TheUser
    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
    by TheUser
    Hello to everyone ,
    This is my first post here, and i would like to share with you a small story in case you can help me.
    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
    02-10-2024, 02:07 PM
  • rumpumpel1
    ThinkPad X12 Detachable Gen 1: keyboard after firmware update without function
    by rumpumpel1
    Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?
    10-24-2024, 08:59 AM
  • dkneyle
    Sony KDL-46HX850 Can't upgrade/update firmware
    by dkneyle
    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
    09-25-2024, 10:44 PM
  • piernov
    Infineon TPM firmware update files
    by piernov
    Infineon TPM firmware update files:
    Infineon_firmware_update.zip
    Code:
    TPM12_4.32.879.0_to_TPM12_4.34.1010.2.BIN
    TPM12_4.33.949.0_to_TPM12_4.34.1010.2.BIN
    TPM12_4.40.119.0_to_TPM12_4.43.257.0.BIN
    TPM12_4.40.119.0_to_TPM12_4.43.258.0.BIN
    TPM12_4.40.119.0_to_TPM12_4.43.259.0.BIN
    TPM12_4.40.119.0_to_TPM20_5.62.3126.0.BIN
    TPM12_4.40.119.0_to_TPM20_5.63.3144.0.BIN
    TPM12_4.40.119.0_to_TPM20_5.63.3353.0.BIN
    TPM12_4.42.132.0_to_TPM12_4.43.257.0.BIN
    TPM12_4.42.132.0_to_TPM12_4.43.258.0.BIN
    TPM12_4.42.132.0_to_TPM12_4.43.259.0.BIN
    10-25-2025, 10:09 AM
  • pp74
    Marantz NR1508 USB firmware update image
    by pp74
    Does anyone happen to have the latest firmware for the NR1508? Marantz took their update server down and customer support refuses to provide the image to flash over USB.
    Regards
    05-10-2025, 11:55 PM
