Yamaha DXR15 Powered Speaker Fault LED On
  • MobileXT
    • Oct 2012
    • 213
    No short to C137 and C138 same reading on the working amp also Q106 and Q107 same reading on the working board also same on all reading on all PIN on IC101 same as the working amp.. Where the -55V and +55V generate? is this from the T102? and the T102 controlled by IC101?
    • madan1
      • Nov 2016
      • 698
      • Bulgaria
      #42
      SM page 101
      T102 pins 9 and 11 are for the +/-55
      The same transformer is used for the rest of the power rails, so if you have any power on the secondary side - the smps IC is doing its job.
      If the 2x55V coil is not generating power, but the rest power rails are present, the coil might be gone.
      • madan1
        • Nov 2016
        • 698
        • Bulgaria
        #43
        Another updates: I received my complete donor for DXR15 amp so I removed the tweeter amp and replaced my old one and now everything is working now two speakers back to life. So Now I like try to fix the donor amp that the problem was not turning on. No green lights missing the -55V and +55V. Also want to fix the tweeter amp. But I like try to fix the AMP board first then the tweeter amp.
        If the original unit started working with another twamp board, this most likely means that all of the time there has been audio signal coming from the DSP. It will save you a lot of time (and nerves) if you make sure that you are testing correctly.. just a friendly advice .
        SM page 108
        The twamp is tda8922. Looks like the protection circuit of the IC is integrated with the rest of the system, so I guess if there is something wrong with its power supply (ig missing rail) the whole unit will be in protection mode. I bet the TDA failed, but still start with the standard procedure - is there power to the ICs on the board (keep an eye which power rail to what is referenced), etc.
        • MobileXT
          • Oct 2012
          • 213
          The CPU must have detected that the tweeter amp is not install. that’s why no audio at HF coming out from the DSP I’m just guessing. I did install the tweeter amp on the working speaker and did duplicate the problem no audio on the Tweeter so I know that the tweeter amp is not working.
          SM page 108
          All the power supply is there I’m guessing is the audio line is broken somewhere. I already replaced the TDA still same problem so is not the TDA. I will double check again all the power supply on the T-AMP.
          • MobileXT
            • Oct 2012
            • 213
            SM page 101
            I believe there’s no power rails on all secondary but will double check again.
            • madan1
              • Nov 2016
              • 698
              • Bulgaria
              #46
              For the twamp board, you have floating ground (KG +27.5 in reference to ground) which goes to pin2 on the TDA. TDA pin 1 should be -27.5 in reference to KG (pin2). TDA pin3 should be +27.5 in reference to KG.
              TDA pin1 to pin3 should be +55.
              On the same board is the oscillator for the TDA - IC503. Again it uses KG for ground. IC503 pin8 to pin16 should be +5V
              p.s. check pin 6 MODE on the TDA - it should be >4.2V in reference to KG
              Well not many places to lose the audio signal. Only a couple of caps and inductors between the connector and the TDA - L503, L502, c511 and c512. Check their connectivity to the connector and to the TDA. On the output side - only a couple of inductors.
              Also, I find it highly doubtful to lose both signals at the same time. If one is missing you will still have o̶n̶e̶ ̶s̶i̶d̶e̶ ̶o̶f̶ ̶t̶h̶e̶ ̶s̶i̶n̶e̶ ̶w̶a̶v̶e̶ ̶a̶n̶d̶ distorted audio on the tweeter*.
              If you are sure that the TDA is fine, then start checking the passives around it and the oscillation signal from IC503.
              *at least that is what I had, when was troubleshooting similar TDA with a faulty channel.
              For the donor unit - if there is nothing on the secondary side, start checking the following on the primary:
              sm page 101
              voltage across C118
              Q106, q107 for shorts
              voltage on c184 and c127
              • MobileXT
                • Oct 2012
                • 213
                sm page 101
                voltage across C118
                Voltage Across C118= 167V
                No shorts for Q106 and Q107
                Voltage On C184= -81.7v
                Voltage on C127= -81.4V
                • madan1
                  • Nov 2016
                  • 698
                  • Bulgaria
                  #48
                  This can't be right.
                  The power on that rail is generated from the feedback/bias winding on T102 and after rectified by d113 , if I remember correctly, should be around 20Vdc (measured on c127). Regulator IC102 makes the 12Vdc (measured on c184/c125) needed for the smps IC101
                  • sukaht
                    Yamaha MSR400 - Powered PA Speaker
                    by sukaht
                    Hello everyone.
                    I need help with my Yamaha MSR400 - Powered PA Speaker that I bought it used recently.
                    It is power on, and sounding good / working perfectly fine. However after 3 - 5 minutes, the heatsink is starting to get warm, and it smells burning a little bit.
                    I did tried multiple times on different day, event the speaker is not playing any song (input does not connect to any source, and the volume level is zero), after it turns ON, 5 minutes later, the heatsink is starting to get warm, and it smells burning a little bit. I am afraid keeping it ON longer than 5 minutes...
                    11-02-2024, 07:55 PM
                  • GerryT
                    Electro Voice SXA series 100 or 250 powered PA speaker Schematic needed
                    by GerryT
                    Does anyone happen to have a schematic for the amplifier for an Electro Voice SXA series 100 or 250 powered PA speaker?
                    09-17-2023, 10:12 PM
                  • JimBanville
                    Switched speaker impedance selector w/ Yamaha HTR-5740 RX-V450 powered on!! Problem?
                    by JimBanville
                    So I didn't realize there was a tiny written warning on the speaker impedance switch on the back that said moving the switch with the power on "may damage the unit". I actually switched it multiple times, listening for any possible audible changes. It wasn't until later I saw the tiny warning. I haven't noticed any issues though. Can someone please look at the schematic and tell me what damage I may have caused? Thanks!!...
                    01-25-2021, 08:45 AM
                    Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
                    Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
                    various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
                    Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
                    trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
                    what is wrong with your PC in just seconds. It saves you time and money.
                    Our new and improved design...
                    11-01-2024, 06:29 AM
                    HP ProDesk 600 G5 + Bluetooth Speaker 400 ProDesk 600 i7-9700 Specification for Upgrade or Repair
                    This specification for the HP ProDesk 600 G5 + Bluetooth Speaker 400 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Bluetooth Speaker 400 boardview and ProDesk 600 G5 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                    09-12-2024, 02:30 PM
