Genelec 8020C Bad capacitor
  • TomGJ
    • Nov 2024
    • 3
    Hi All, So I have two Genelec 8020Cs that are about 10 years old, one of them stopped switching on. I took it apart, fuse was blown, and I've traced the short to one of the two large capacitors on the circuit board.
    Now from looking at the Capacitors, they seem to be from Samwha's SD Series with the following specs: 3300uf, 35v, 85C, 25 x 16 mm Radial.
    The problem is, I can't find any capacitor from Samwha's SD Datasheet that matches these specs. The closest is 3300uf, 35v, 85c but 31.5 x 16mm, with a max ripple current of 2.5A. I'm guessing the 25mm is custom made for Genelec, and would have a correspodingly ca. 20% lower ripple current.
    The closest replacement I can find is this: https://www.mouser.de/ProductDetail/...QB4xyb2g%3D%3D
    This matches the specs, expcept it only has a ripple current of 1.7A, however this is at 105C, I'm guessing it would be higher at 85C.
    My question is this - Would replacing these Samwha Caps (I would do both) with the Rubycons probably be ok, or is it a bit of a gamble?
    Many thanks in advance
    Click image for larger version  Name:	IMG_20241031_133906.jpg Views:	0 Size:	1.61 MB ID:	3498484
  • check12
    • Nov 2012
    • 103
    Remove the cap you think is shorted and test it while it's off the pcb.....good chance it's not shorted and the short is something else...
    • R_J
      • 9545
      It is likely the output ic LM1876T is shorted.
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
      • Prolog
        RTX 3080 FE Identifying capacitor
        by Prolog
        Hi people, I hope this is the correct spot to post this, I'm new to the forum.
        I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
        I hope these photos make it clear which component I am referring to:
        (yes, the soldering is a bit botched from removing the blown one, I know)
        I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
        12-01-2024, 08:27 PM
      • chth96
        How can I test non-polarized capacitor?
        by chth96
        I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
        I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
        And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
        I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
        06-02-2024, 07:31 PM
      • SluggerB
        Can't find exact matching caps for replacements, what should I get to prevent video issues?
        by SluggerB
        I have an old Tivo. The Power Supplies are known to have caps that fail. Here are the caps that come with the original power supply:
        I could not find replacement caps with the exact same specs. I followed an online guide and recapped the power supply with caps with these specs
        The power supply now works, however the HDMI video is giving me eye strain. I don't know how a capacitor on a Power supply could impact an HDMI video signal, but it does, the Tivo interface has a flicker now and the color/brightness is off. So I want to get some new caps...
        04-05-2024, 07:47 PM
      • chth96
        Should I replace polymer capacitor?
        by chth96
        a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
        I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
        Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
        Is this ESR value of polymer capacitor correct?...
        11-18-2022, 04:22 AM
