NAD 3140 phono input mistake !!
  • guizmo1967
    • Sep 2022
    • 77
    I accidently connected my aux input (TV) to phono1 and now phono1 is louder (volume higher than phono2).
    If I don't touch the volume knob and switch my turntable to phono2, the sound is very good on both but phono2 is just lower than phono1 ???
    Do you have any idea why ??
    I look at the service manual and there is two 330K resistors connected to ground and to each phono inputs. Do you think that could be one of those resistors ?
  • petehall347
    • Jan 2015
    • 4451
    yes check those resistors and clean the switch
    • R_J
      • Jun 2012
      • 9633
      The phono inputs are for different output cartridges, see manual
      Phono 1 is for high output cartridges so its level will be lower compared to phono2 using the same level of source
      This is normal and there is no fault with the amp.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        I put much higher levels of audio into a phono jack than there should be without any ill effects. Like R_J noted, there are amps that have different level phono jacks. This one seems to be one of them.
        • guizmo1967
          • Sep 2022
          • 77
          I just read the phono input section of the Owner's manual and this paragraph explains everything:
          For phono 1:
          "This input may also be used with cartridges of other types which have lower-than-normal output voltage such as ..... The phono 1 input has a standard input impedance (47K ohms resistance, 100pF capacitance) but is 10 dB more sensitive than phono 2 input"
          That's why with the same turntable and cartridge, phono 1 has a higher output level than phono 2 !!
          Glad there is nothing wrong with my amp !
          Thank you R_J !😉
          • ugamazing
            820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
            by ugamazing
            So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
            1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
            2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
            04-10-2024, 08:06 AM
          • TinkerTron
            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
            by TinkerTron
            Hey everyone,
            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
            Instead, here's what's been bugging me so far:
            The schematic...
            03-06-2025, 02:03 PM
            Acer Aspire A315-51-3140 Notebook 3 Specification for Upgrade or Repair
            This specification for the Acer Aspire A315-51-3140 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A315-51-3140 boardview and A315-51-3140 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-06-2024, 06:00 AM
          • brightest_z
            Hot Air Blew Away Resistors Near Bios
            by brightest_z
            Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
            Does anyone with more knowledge, and experience than I, know if this is the case?
            12-11-2024, 08:34 PM
          • karatzdi
            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
            by karatzdi
            I know some might say... just buy another one. Sell it as parts..!
            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
            Spent some time downloading the Service...
            06-11-2024, 08:38 AM
