Behringer xenyx x1204usb mixer
This topic has been answered.
For confirmation can you post a photo of the 3B503x pot... I want to make sure it's a vertical pot?
Originally posted by Thermaltake View PostForgot one pot
It's also FX central pin - 3B503x (6 pin)
Another question
If I want to change caps on motherboard of mixer, do I need to put low esr caps or normal caps ?
Easiest way to replace caps in behringer power supply is to use 105c (temperature) low esr for all replacements.
IMO your doing a lot of unnecessary work... What is actually wrong with the desk?
Forgot one pot
Another question
If I want to change caps on motherboard of mixer, do I need to put low esr caps or normal caps ?Last edited by Thermaltake; 11-05-2024, 03:05 AM.
Originally posted by check12 View Post
For headphones= Search Google for "B503 linear 50k ohm vertical no detent dual 6 pin pot“
For FX= Search for "B503 linear 50k ohm vertical center detent 3 pin pot"
For low, mid & high EQ= Search for "B503 linear 50k ohm vertical center detent dual 6 pin pot"
For balance (pan?) = Search for "AC taper 10k ohm vertical center detent dual 6 pin blend pot"
AC taper blend pots can be difficult to find but don't often need replaced.
There's no way I have time to search for where you can get the cheapest parts, you will have to do that yourself... I have provided what to search for.
Pots made by Bourns, Alps, Alpha (Taiwan)... are the kind of product you are looking for.
If you are unsure about what you find then post the links where you want to buy and I or others will confirm if suitable.
Ok, I'll try to find them in few days and post links for you to confirm if I pick right ones, thanks!
Can you tell me just am I searching for shaft 18mm or 23mm ? How is it measure from metal part or just plastic thing ?Last edited by Thermaltake; 11-05-2024, 01:39 AM.
I finally manage to disassemble the mixer.
All pots have 1,8cm shaft measuring only plastic part. From metal part of pot to top of shaft is 2,3cm
Here are mark of all pots inside mixer:
For headphones - B503DC (6 pin)
For FX With central pin - B503x (3 pin)
For Balance With central pin - AC103w (6 pin)
For low, mid and highs With central pin - B503w (6 pin)
If someone can help me to pick some high quality pots to replace them with this behriger garbage ones. Thanks
Originally posted by check12 View PostJust saw this ... haven't got time right now but tomo evening maybe ... I'll post the values etc. unless someone else does it first ...
If it's possible for shop to be in EU, to avoid extra VAT to pay.
Originally posted by check12 View PostThen you need to list the serial numbers on each pot and also the number of pins... I am not telepathic... 😵💫
Originally posted by CapLeaker View Post
Huh? You lost me. What caps? Take each style pot out you need, as you said you need a few different styles. Behringer stuff is all made in China. No point on really doing any upgrade if you ask me. These mixers aren't anything special at all. Just make sure you order a couple more than you need from Ali or whatever, so you got a spare. Make sure you have good solder and solder flux. Don't burn anything because of not using the stuff and Bob is your uncle. Behringer is German design, made with cheap China parts in China. Not worth spending the extra $$$ nor the effort. I fixed a few of these suckers.Last edited by Thermaltake; 10-07-2024, 05:02 AM.
I tried aliexpress, but I could only find original ones, and those cheap ones I don't want on my mixer anymore. I want to put all high quality pots.
Never heard of LCSC. But TME I was ordering from them, they are ok. But I don't understand what check12 was explaining to me in post about caps. I need someone to tell me this one you need and this one you need. On mixer I have few pots with different values PN. They are not all same.
The plastic thing is called the "shaft", my link was just an example ... most pots are available in long and short shaft versions.
This guy that I couldn't remember earlier was a wealth of knowledge about replacement pots for behringer if you can't find them locally, maybe good for a deal if you want multiple pots: https://www.theaudioguyuk.com/produc...ntre-click/106
If it's Panasonic pots he's selling then they are pretty good ...
Originally posted by Thermaltake View PostThat plastic thing where cap is going in is shorter on your link then mine. I think mine is 23mm not sure now, I will need to measure.
Tnx for explanation.
In what way is the "shaft" wrong? Is it wrong type or too long (just cut to length)?
To decode the number :
The letter is the taper: B = Linear
The number is the value: 503 = 50 followed by 3x zeros =50000
The number of pins: 6 = dual gang or dual channel
So you are looking for a "Linear 50k dual gang pot"
The shaft = splined or D shape & either order correct length or cut to size.
Bourns are one of the best common pots, Alps are good too as are Alpha (Taiwan)... NOT the super cheap alpha copies from China.
There used to be good supplier in the UK who was familiar with all the different Behringer pots, I can't remember his name but I will post if it comes back to me.... 👍
Originally posted by check12 View PostHere you go.. B503 is the important part of the number + 6 pins.... https://uk.rs-online.com/web/p/poten...B&gclsrc=aw.ds
I couldn't find this two AC103w and B503w pot. Can you help with this one ?
https://i.imgur.com/gTV73lf.jpg
https://i.imgur.com/hqZI27d.jpg
Bourns is good brand ? Someone told me to look for alps potentionmeters but I am not into pots so I don't know if that brand is any good.Last edited by Thermaltake; 10-05-2024, 01:03 AM.
Originally posted by check12 View PostYou need to remove it... the value is usually stamped on bottom... 👍
Here are picture of that one, it has some numbers on metal but when I google I can't find anything.
https://i.imgur.com/goJVbjD.jpeg
https://i.imgur.com/eriepuj.jpeg
But I would like to replace all of them on mixer with better quality ones. They are not the same, some have center, some don't.Last edited by Thermaltake; 10-03-2024, 09:23 AM.
