Kenwood VR-505 Receiver No Audio, Loud Popping
  • Robb
    • Sep 2013
    • 159
    I have a Kenwood VR-505 AV Receiver that powers on with display. It allows me to navigate the menu but I can't get any sound to come through and when changing the volume or switching input it makes a horrible popping or cracking noise. Does this sound familiar to anyone?
    Service Manual -
  • particleman
    • Mar 2014
    • 28
    Re: Kenwood VR-505 Receiver No Audio, Loud Popping
    I would try cleaning pots with deoxit.
    • rievax_60
      • May 2012
      • 897
      • australia
      Always a good idea to check all of the rails.
      • Robb
        • Sep 2013
        • 159
        Good idea, been meaning to get some anyway.
        Originally posted by rievax_60
        Always a good idea to check all the rails
        Also a good idea but not sure where to check the voltages.
        • particleman
          • Mar 2014
          • 28
          You will have to d/l that service manual and it should show you voltage check points. Also those IC transistors (they may say darlington powerpack) that are screwed to the heatsink. A lot of the time those are bad you will need a volt meter. You will have to look up the type of module like stk-0050 or what ever. I have a kenwood ka-92b that had only one channel and needed the IC transistor replaced. I Also have a JVC that used stk-0050 darlington powerpacks and they both needed to be replaced. Once you figure out the module type you will be able to check resistance between the pins to find out if the module is bad.
          • Robb
            • Sep 2013
            • 159
            Thanks for helping me with this.
            I d/l´d the SM but it's mostly just schematics which of coarse is good for someone who can read it still trying but it's slow going.
            I checked the volts in/out of transformer
            In: 120V, 1.2V
            Out: -22V, -22V, 16V, .005V, 16V, 50V, 31V,.003V, 31V, 4V, 4V
            Seems like some are low but it could be normal. I noticed some caps were rated at 75V and I'm not seeing any that high....
            Those STKs seem a likely culprit as absolutely no sound emit except the popping and they're cold while other FETs/ICs seem to pass diode tests and get warm. But then again maybe they're not getting powered....
            I will look into testing them.
            Edit: I have an Oscope and ESR meter
            • Robb
              • Sep 2013
              • 159
              Apologies for double/triple posting but I'm having a hard time finding datasheets on these...anyone know a good source for datasheets?
              STKs:
              STK413-020A STK412-020A
              • particleman
                • Mar 2014
                • 28
                Just because the caps are 75V rated does not mean they will ever see that. The S/M should show you what the output from the power supply should be.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4962
                  • New Zealand
                  STKs:
                  Sometimes it helps to search the main IC number eg STK412 without the suffix as some ICs in a family will have the same datasheet.
                  A schematic is easy to read. It's nothing more than a diagram showing component symbols and the connections (lines) between them.
                  For something like your amplifier there are many connections so there are many lines. One thing to note is that to avoid even more lines (and because there are multiple pages) not all lines will be drawn.
                  Some lines will be given a name (like Ground) and all lines with that same name are actually connected together, even if it's not shown directly.
                  In: 120V, 1.2V
                  Don't worry about the transformer too much. You want to check the output of the regulators etc. Page 13 of the schematic shows the transformer at bottom right and there are 3 diode bridges D1, D2 and D3 to the left of it. Also note regulators IC5 and IC6.
                  Each of these shows labels with voltages, You should check at those points for correct voltage to start with.
                  If the voltages are correct, make sure they are actually getting to the ICs.
                  The board layout on Page 10 shows where these components are physically on the board.
                  Possibly they are bad, though it seems odd that both would fail at the same time. That would point to something else causing them to both not work.
                  They may have bad solder joints. There may be a problem with circuitry that affects both of them, eg: preamp, muting circuit etc.
                  A scope would be good for audio signal tracing. ESR meter probably not so much in an amplifier.
                  Last edited by Agent24; 05-07-2014, 07:06 PM. Reason: Attached datasheets and manual for convenience
                  -David VanHorn
                  • Robb
                    • Sep 2013
                    • 159
                    Wow, thanx for all the practical info
                    D1, D2, D3 all had correct voltages
                    IC5, IC6 should have had +20V/+12V & -20V/-12V respectively, however, all I could get was +20V from IC5 & -12V from IC6 the other two legs on each IC had .00xV. I found the ICs for $6/...ya think that's it?
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4962
                      • New Zealand
                      You should get 20v on the input of IC5 and 12v on its output. Similarly, -21v on input of IC6 and -12v on the output.
                      Measure with respect to ground - put your meter negative lead on ground, probe the other two pins.
                      Note on Page 10 how IC5 and IC6 don't have the same pinouts for input, output and ground.
                      -David VanHorn
                      • Robb
                        • Sep 2013
                        • 159
                        I can't tell you how much I appreciate your putting the schematic into perspective for me...makes alot more sense to me now.
                        On IC5 I got +20V, .003V, .005V & on IC6 I got -12V, .003V, .005V. It looks to me like IC5 & IC6 need replaced.
                        UTSOURCE has the ICs for $2/each + $4 shipping so I'm going to replace em & hope for the best, unless otherwise advised.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4962
                          • New Zealand
                          No worries, glad I helped
                          Those readings are a bit odd, if you say the voltages from all the diode bridges are correct. Are you getting the +/-20v rails from the D3 bridge rectifier that feeds IC5 and IC6?
                          Are getting the +20v and -12v at the inputs to the regulators or the outputs? I assume at the inputs if your outputs are only millivolts. Did you check D3 and the regulators for dry solder joints?
                          In any case, new regulators are cheap but not sure I would buy them from eBay, especially China. If you can get them from Digikey\Mouser even RS etc that would be better.
                          -David VanHorn
                          • Robb
                            • Sep 2013
                            • 159
                            I was checking the voltages from the legs of the components. The diodes had four legs each. The outer two legs produced significant voltages - which were correct. The inner two legs did not.
                            As for the ICs, I think I should have measured a current on all three legs of each of the ICs, but I could only find volts on one of each.
                            I don't think there much between the Trans/diodes/ICs so, if I am measuring from the right spot, I'd guess it's the ICs...can't think of anything else at least.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4962
                              • New Zealand
                              The diodes (actually diode bridges as they have 4 diodes in each) take AC in on the inner pins (those marked with a ~) and rectify it to produce DC on the other pins marked + and -
                              If you are in DC volts mode when you measure the bridge input it will show nothing because there's actually AC there.
                              The regulator ICs should have an input voltage and an output voltage - and nothing on the third pin because it's ground.
                              I don't know how you checked before but the correct way would be this: If you look at the board overlay you will see how IC5 and IC6 have their leads labelled with G, I and O. G is Ground, I is Input and O is Output. Note also that the pin functions are not the same on each regulator.
                              Take the negative probe of your voltmeter and put it on the Ground\G pin, and then test the input and Output pins. Do the same for the other IC.
                              -David VanHorn
                              • Robb
                                • Sep 2013
                                • 159
                                My previous voltage test was taken w/multimeter ground on a ground screw. I retested w/MM ground on the ground (middle) pins of IC5 & IC6 & got 20V/9V & -20V/-.5V where it should have read 20V/12V & -20V/-12V.
                                I also retested D1, D2 & D3 & got -66DC/50AC/50AC/66DC; -40DC/30AC/30AC/-40DC; -20DC/16AC/16AC/20DC respectively. The DC outputs were correct but I couldn't find a reference for the AC inputs.
                                Seems like IC5 should have 12V output instead of 9V & IC6 should have -12V instead of -.5V. Is it common for both to go out & is the 9V output within working range?
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4962
                                  • New Zealand
                                  I don't know about common failures on those regulators but yes, those voltages are wrong. 9v is not correct for a 12v regulator. It should be 12v.
                                  Since the input voltages are OK, Either the regulator is bad, or something is shorted and loading it down, or the filter capacitors for it are bad.
                                  You might as well replace the regulators anyway, but there may be other problems too.
                                  -David VanHorn
                                  • Robb
                                    • Sep 2013
                                    • 159
                                    Ok, I'm going to go ahead & order the regulator ICs. Thanx for clearing things up for me.
                                    I'll post the outcome of the replacements. Cheers
                                    • JRade
                                      Audio video receiver KENWood KR-V990D,no sound
                                      by JRade
                                      When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
                                      The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
                                      I replaced the capacitor C303/0.047F, nothing changes.
                                      I'm asking for help, what should I do next?
                                      Thanks in advance!...
                                      08-05-2025, 10:23 PM
                                    • samson7point1@yahoo.com
                                      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                      by samson7point1@yahoo.com
                                      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                      The player processes the audio signal using two different reference frequencies. The "R"...
                                      04-30-2024, 11:22 AM
                                    • Cornito
                                      Denon AVR-2700H audio stops while receiver still works
                                      by Cornito
                                      Hello team,
                                      I've got a new issue with a Denon Avr-2700H.
                                      After several minutes working, receiver stops playing sound with a poc eared in the speakers.
                                      Receiver still work and display video with error message on display.
                                      Seems to me that is the main output relay.
                                      I'm looking for the service manual that I can't find for the moment.
                                      Does somebody have it?
                                      Regards...
                                      08-03-2025, 06:10 AM
                                    • acedogblast
                                      [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
                                      by acedogblast
                                      First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
                                      Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
                                      03-01-2023, 08:24 PM
                                    • mitsu2k
                                      Repairing Kenwood XR900-5 car audio amp. Can't identify missing part
                                      by mitsu2k
                                      Hello folks, I am trying to repair this Kenwood XR900-5 power amp. Someone else had previously worked on this amp and tore off a transistor (Q982, pad and all) and I cannot identify what it was without a schematic or service manual. The one near it is an 2SCR533 NPN. I am wondering if the missing one is likely to be the same or a PNP? Can anyone make a good guess based on the photo?...
                                      12-23-2023, 02:09 PM
