Noob attempting to fix a blown NAD T-760 AV receiver
  • Agent24
    I see dead caps
    • Oct 2007
    • 4913
    • New Zealand
    #41
    Re: Noob attempting to fix a blown NAD T-760 AV receiver
    According to the schematic pin 5 of U109 is supposed to connect to analog ground, so that jumper was probably installed in factory to fix a PCB error.
    -David VanHorn
    • Gatchaman
      • Mar 2014
      • 38
      #42
      Okay cheers. :-). Still looks bloody crude for a in-house job though.
      • Gatchaman
        • Mar 2014
        • 38
        #43
        Went back to the site where the transistor exploded and tested a few more things around the area. Looks like a load of resistors in the K ohm range have lost resistance and dropped down to silly levels. Going through the components near the transistor but this time I'll look at a larger area and build a proper parts list. CPC here I come..... again :-)
        Used the new soldering iron today and I'm such a tit for not upgrading years ago. Wow is all I've got to say.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4913
          • New Zealand
          #44
          Resistors don't typically drop in resistance. Their resistance can increase or they can burn out and go open-circuit but due to the physical construction it's practically impossible for a resistor value to drop.
          Likely you have misread the value (some of the colour bands can look really similar in bad light) or you are testing them in-circuit - make sure you at least desolder one lead or remove the resistor completely before testing. If you don't, other components in parallel with the one you are testing will cause the reading to be wrong. Also make sure your multimeter has a good battery - a low or flat one can seriously throw some readings off.
          Check the schematic and find which parts are actually connected to that transistor, don't just test things near it because they may not actually be electrically connected to it.
          Good to hear!
          -David VanHorn
          • Gatchaman
            • Mar 2014
            • 38
            #45
            Cheers and will do!
            • Agent24
              I see dead caps
              • Oct 2007
              • 4913
              • New Zealand
              #46
              From the idea here: http://www.repairfaq.org/REPAIR/F_au...#AUDIOFAQA_013
              You should be able to narrow down whatever is tripping the protect circuit to a specific channel.
              See pages 29-32 for front and rear amp schematics. Speaker outputs on the right are switched on and off with relays, M501 and M502 on the front board, and M801 on the rear board. Check the inputs to these as stated for DC.
              Also note on page 11 there are 5 test points (one for each channel) which are supposed to be set to 2mV for an alignment procedure - but in the case of a fault they may end up being wrong as a symptom. I would check all these for discrepancies against the spec and against each other, it may also help find where the fault is coming from.
              Remember too if you compare other voltages at the same points at each channel and find that one is different from the others, that may well be your problem area
              -David VanHorn
              • cmlewis89
                LG 47LB5DF blown power supply board
                by cmlewis89
                Hi folks,
                I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                09-03-2024, 07:50 PM
              • drscoot
                HP X360 convertible battery blown fuse error, not charging
                by drscoot
                HP Modelnumber: 14-dh0061nb​
                This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                All these 3 batteries are charging...
                12-15-2023, 05:54 AM
              • CdDvdFlash
                DSE GE6878 possible TV receiver dying remote not working well
                by CdDvdFlash
                For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
                07-03-2024, 03:55 AM
              • swerg
                Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                by swerg
                Hey everyone,
                I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                06-06-2024, 03:39 PM
              • MrzPdlch
                Blown fuses on Gigabyte GTX 980TI 6GB
                by MrzPdlch
                Hey everyone,
                I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                Find some pictures of the actual GPU together with a picture of how it should look like.
                I also wonder whther it might be a problem that there...
                03-10-2024, 04:14 PM
