Yamaha RX-V671 in protect mode
  • tibimakai
    • Jan 2012
    • 3680
    I have picked up this receiver and I'm trying to repair it.
    I have found already some transistors and diode that are blown.
    I haven't get around yet, to check all the components, just the semiconductors and the Emitter resistors. The resistors are fine.
    Digikey has the final transistors.
    I'm having problem finding these components, like:
    2SD2705S
    2SA1770
    2SC4614
    MTZJ5.1C zener
    Any pointers, or equivalents that I could use?
    Any help would be appreciated.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Yamaha RX-V671 in protect mode
    I have found 2SA1770 and 2SC4614 at Mouser.
    • shaunbt123
      • Nov 2012
      • 119
      • uk
      Is this one of the parts you need. (MTZJ5.1C zener) . it also lists an alternative part.
      https://www.encompassparts.com/item/...T2/Zener_Diode
      • tibimakai
        • Jan 2012
        • 3680
        It seems like the right part. Thank you.
        • tibimakai
          • Jan 2012
          • 3680
          Just an update, I have replaced those components and the receiver still didn't want to show any life.
          Then I thought maybe I should reset the receiver to clear the protect mode error and then it turned on and since then it's working great.
          It's a very nice receiver.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            I have a receiver like this.
            How did you reset this unit?
            What procedure did you use??
            • tibimakai
              • Jan 2012
              • 3680
              I don't remember, but here it is the service manual:
              http://elektrotanya.com/?q=showresult
              After clicking on it, you will have to wait like 15-20 sec. and a Get Manual will appear below the service manual's picture.
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                Thanks, Man
                AFA
                • Brianwitty
                  • Dec 2014
                  I'm about to start work on one of these- first post noob here guys sorry- I have worked on a number of tube amps but this will be my first modern solid state av receiver. There is no sound. It was pushed hard in a home theater system that the speaker wires got compromised by mice. It first lost some speakers, then all. I'm guessing all of the output transistors need to be replaced, but have not tested it yet... Any advise?
                  • Dvsr
                    On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                    by Dvsr
                    Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                    I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                    After replacing the caps I started testing out the speaker. It seemed...
                    09-10-2025, 10:20 AM
                  • karatzdi
                    Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                    by karatzdi
                    I know some might say... just buy another one. Sell it as parts..!
                    So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                    Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                    Spent some time downloading the Service...
                    06-11-2024, 08:38 AM
                  • caspian
                    What Zener Diodes on a Linear Power Supply
                    by caspian
                    Dear members,
                    I have a linear variable power supply with unknown brand name that I used for voltage injection.
                    Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                    In addition, I discovered that its zener diodes are defective.
                    I can replace the burned transistors.
                    But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                    Therefore, I cannot replace the zener diodes.
                    I do not want to test the zener diodes in a test circuit to discover their model or value.
                    no schematics are available...
                    05-26-2025, 12:38 PM
                  • TinkerTron
                    Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                    by TinkerTron
                    Hey everyone,
                    I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                    Instead, here's what's been bugging me so far:
                    The schematic...
                    03-06-2025, 02:03 PM
                  • dicky96
                    Dynacord PowerMate 600 Powered Mixer - Protect Light On
                    by dicky96
                    Hi guys
                    I'm trying to repair this powered mixer. Sorry this is a bit long but I want to give as much info as possible to help get an answer,
                    As soon as it powers on the protect light comes on. There are relays that connect the speakers to each channel of the amplifier but they never click. If I connect a 60W light bulb in series with the mains supply it comes in bright then goes to maybe 30-50% brightness - it seems to dim a little further over time
                    I have power to the amplifier, I think it was as about plus/minus 50-60V for the main amp, and plus/minus 15V...
                    05-22-2022, 04:36 AM
