Help diagnosing dim VFD on Yamaha RX-V2400
  • JimBanville
    • Aug 2020
    • 118
    I realize vacuum fluorescent displays degrade over time.
    Potential "fixes" (temporary or permanent) seem to typically involve replacing capacitors powering the VFD, or the risky and temporary "fix" of high voltage across the filament to burn off contaminants.
    Can someone look at these pics from the RX-V2400 service manual and give me a starting point in determining which step to take first? The display is almost too dim to even read, so if I damage it, so be it. It's borderline useless at this point. I already did a factory reset which didn't help. It looks like power for the display comes straight from the transformer. I don't see any capacitors in the circuit. What voltage should be going to the display? THANKS!
  • redwire
    • Dec 2010
    • 3912
    A really dim fluorescent display is commonly the HV power supply (capacitors). Or the display dimmer function is turned on...
    Check the VFD VP is -33.3V, starting at the power supply conn CB207 (H1). Q257 regulates it. If it is low, look at C207 100uF 50V (runs at 45V wow so conservative) and C510 47uF 50V is stashed away on the Function Board 1, doing a loop dee do connector MAIN E7 to OPERATION(1) H1. Ugh.
    For the VFD filament power, a bad connection is a common occurrence but what typically happens then is the VFD just goes out - not consistently dim.
    You can measure the ACV at the outside ends of the tube (pin 1 FL1 and pin 65 FL2) 6.9VAC, and to GND those two (heater) are biased at -25.7VDC by zener D851, D852, so measure that as well.
    VFD filament connections are usually cracked due to bad soldering of the Kovar pins. You can see there is a long, convoluted path from the power transformer, a few hops through connectors and ribbon cables to the display board. So many places where a bad connection can happen. But vibration and tapping can flush that out.
    If the tube has aged- it can be due to low emission or phosphor burn or grid contamination.
    VFD phosphor burn- segments that are always on will appear dim and a bit fuzzy looking around the edges- but rarely used segments will have good brightness.
    If the entire display is dim, all elements- then due to aging it can be contaminants on the heater that can be burned off to rejuvenate the VFD.
    Grid contamination is another aging mechanism but complicated to deal with.
    • JimBanville
      • Aug 2020
      • 118
      Thanks! Here are the measurements for H1... -31~0~5.3~0~4.9~5~5~5~5~4~0~0~4.8~4.6~4.8~4.8~0~0~0~0~5
      Filament measures 7v AC when unit is powered on. 0v when powdered off.
      I found Q257 on Main 1 PCB, but did you mean C270? I don't see C207. Unfortunately those are too deep to get to without a lot of disassembly. As far as C510, I measured 31v on one lead and 5.6v on the other lead.
      • redwire
        • Dec 2010
        • 3912
        VFD power VP is a bit low. Your -31V vs -33.3V it could be a problem if it's got a lot of ripple due to an open filter capacitor C287 (not C207 I read that wrong) on MAIN(1). Q257 is the regulator. If C287 died then C270, C271, C510 may also have gone low value due to stress. These AV receivers always have hot spots where some parts just get baked, causing them to fail. I would expect -45V in and -33V out of Q257. Or measure ACV on it to see if there's ripple.
        Check the VFD cathode bias by measuring DCV to GND at each filament pin (not ACV), should be -25.7VDC at W851 or the tube ends.
        Other than this, the voltages look reasonable. Maybe post a pic of the dim display so we can see if it looks aged or not. I would go after low VP for now.
        • sanalelevenstar
          Yamaha RX-V485 Wn9711 Update
          by sanalelevenstar
          Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
          I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
          I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
          12-04-2024, 04:32 AM
        • sanalelevenstar
          Yamaha RX-V485 receiver. After encountering a "version error"
          by sanalelevenstar
          I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
          After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
          I managed to find the service...
          09-10-2025, 01:54 AM
        • jjne
          Yamaha RX V675 sound issues
          by jjne
          I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
          From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
          At first I thought it was either a speaker relay or the DSP, but I don't think...
          06-24-2025, 07:01 AM
        • AlexVG
          YAMAHA CLP-550 without of sound
          by AlexVG
          Hi.
          I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
          I have replaced all green marked elements, but it gave me nothing.
          The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
          But it is custom YAMAHA's chip, and I can't find any information about it.
          Maybe somebody came across with the same issue?
          Any information will be very useful. I will be very appreciated.
          Thank you....
          06-08-2025, 09:29 AM
        • hemant_2222
          Yamaha RX-A1020 full dead
          by hemant_2222
          Hello Everyone,
          Greetings!
          It has been very long time that I opened up my garage again because I got something that I could not stop myself and this time I have a Yamaha RX-A1020 super powerful (at least from inside structure 😉 ) AV receiver. When this unit came to me this Saturday it was full of dust and what not but the standby LED blinked when pressed and power relay clicked once but no display. It worked 3 times after normal reset like other Yamaha receivers and then again it had to be unplugged to get his behavior back. I opened everything and cleaned it up and...
          09-14-2024, 11:25 AM
