Need help finding this chip! for an amplified speaker.
This topic has been answered.
  • Gadjet
    • Aug 2012
    • 248
    Looking for a chip and can't find it anywhere, or would anyone know what I could replace it with? Belongs to a powered amplified speaker.
  • Answer selected by Gadjet at 01-13-2024, 12:23 PM.
    StanislavNovak
    • Jan 2022
    You are welcome! I'm glad I could help.
    In case you're wondering how I guessed the part, fortunately, it was fairly well-marked. I wish all the parts were labeled at least to the same extent. You can find the International Rectifier's IOR logo in the lower right corner, so the part number most likely starts with IR. Many manufacturers omit these first characters and leave only the meaningful part, which is either S215310 or S21531D (hard to tell 0 from D from the photo). So you might try googling IRS2153 to see if something like that exists. Infineon does indeed offer a component labeled IRS2153(1)D(S), where (1) stands for the faster deadtime version, (D) means the integrated diode between the Vs and Vcc pins, and (S) designates SO8 package variant instead of PDIP8. This IC is commonly used for constructing switching-mode power supplies, which could be well located inside an active speaker.
    • StanislavNovak
      • Jan 2022
      Hello, I think it is an IRS21531D self-oscillating half-bridge gate driver IC from International Rectifier, which is now Infineon Technologies.
      • StanislavNovak
        • Jan 2022
        Here is the datasheet for it
        The IRS21531DS is a 600 V half-bridge gate driver IC with oscillator, integrated bootstrap FET
        • Gadjet
          • Aug 2012
          • 248
          Thanks for the info I will order one and see if it works, I've been looking for this chip for months!
          • StanislavNovak
            • Jan 2022
            • Gadjet
              • Aug 2012
              • 248
              Part arrived quickly installed and it's now powering on. Thank you so much @StanislavNovak !!!
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • DynaxSC
                ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                by DynaxSC
                Hi
                I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                08-04-2025, 12:20 PM
                Common SPI bios chip programming Questions and Answers
                by SMDFlea
                Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                A: If you can`t read from it how do you expect to write to it ?.
                Q: Why is my bios chip unreadable ?.
                A: The programmer is faulty or has a worn or broken zif socket.
                The USB cable is frayed,connector pins worn or some other physical damage.
                Not enough amperage or voltage to power the programmer properly.
                Bad...
                09-02-2021, 04:40 PM
              • Zilicon
                ATS2835P Bluetooth Chip used in a Zealit Bluetooth speaker
                by Zilicon
                Greetings everyone, please I need help with the above Bluetooth module.
                I was fixing a Bluetooth speaker that was dead, no sign of life. On checking, i didscovered the bluetooth chip ATS2835P got hot.
                I bought a new ATS2835P, the bluetooth flashes red light faintly continuously.
                Does this chip requires programming before it can work?...
                07-05-2025, 02:54 AM
              • BMCappelletti
                Asus Chromebox CN62 - wrong chip put on BIOS reader
                by BMCappelletti
                Long story short:
                - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                - gave the computer to his son a couple years later
                - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                (seems like the story was not that short)
                He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                01-08-2025, 07:27 PM
