Denon AVR 4800
  • shorteddiode
    • 221
    Denon AVR 4800
    I am not getting sound from the Surrond A right side. Only have about .1 Ma output. Anyone else ever had this problem? This maybe a stupid question but I usely only work on tube stuff, so my signal tracer is an old NRI modell 33 tube signal tracer. Is it save to use on the Denon to trace the out put signals?
  • shorteddiode
    • 221
    Re: Denon AVR 4800
    I did more checking and had no DC offset or resistance between the neg and pos speaker terminals. So I kinda discounted a bad transistor or IC chip. Once I opened it up and checking componets I found a bad solderoint at CX944. Now to put all back together and see what happens
    • DCJack
      B&K 707 tube tester. I need help.
      by DCJack
      Hi everyone!
      I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
      Initially I noticed that I was not getting the red on-light to turn on, but it...
      03-05-2024, 05:05 PM
    • Schoenradt
      ECH81/6AJ8 Vacuum Tube Question
      by Schoenradt
      Recently I acquired an Eico HFT 92 AM/FM radio made back in 1958. The unit has had some decent modifications done such as replacing the rectifier tube with silicon diodes and replacing the main filter capacitor with electrolytic capacitors. When I powered it up FM wouldn't tune past 105Mhz. I checked the FM tuner front end assembly and found a capacitor not soldered to the coil from the Plate B+ to and ground on the other side of the coil. Some calibration was needed on the trimmer capacitor on the tuner. My question is AM is extremely weak. When I tap on the tube I get all kinds of snapping and...
      06-10-2021, 05:49 PM
    • falcontech
      Denon Mc6000 channel 1 completely non-functional
      by falcontech
      Hello
      I need your help with a non-functioning channel on this Denon controller. I noticed the problem because, with the mixing software, the channel appears completely off and none of its controls work. At the top of the channel, like the others, there's a selector switch that moves between MIDI and external audio inputs. I also tried connecting an audio source (since it's also a standalone mixer) and I got no input. The flat cable connecting this panel to the sound card is fine. I'm attaching a photo and the service manual. I hope someone can help me resolve the issue. Thanks....
      09-04-2025, 09:03 AM
    • Cornito
      Denon AVR-2700H audio stops while receiver still works
      by Cornito
      Hello team,
      I've got a new issue with a Denon Avr-2700H.
      After several minutes working, receiver stops playing sound with a poc eared in the speakers.
      Receiver still work and display video with error message on display.
      Seems to me that is the main output relay.
      I'm looking for the service manual that I can't find for the moment.
      Does somebody have it?
      Regards...
      08-03-2025, 06:10 AM
    • Green Probe
      Recapping a Denon AVR X6400h SMPS
      by Green Probe
      (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
      Disclaimer: I'm an amateur hobbyist and will get things wrong.
      Always use caution when working around mains power and high voltage capacitors!
      Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
      SYMPTOMS:
      -No display...
      07-18-2025, 03:36 PM
