Tivoli Audio Model One FCC ID issue
  • Jack Crow
    It's a CLASOB!
    • May 2008
    • 823
    All,
    A client gave me a repair to look at this week.
    It's one of those up scale entertainment radios.
    A Tivoli Audio or Henry Kloss Model One.
    This is a premium radio, very good sound, feel, and performance.
    The price is in the 150 buck range.
    A casual web search indicates the company refuses to publish service data on the unit. Something to do with patents.
    OK, there is a way around that, sometimes.
    When ever a product is to be sold in the US it has to meet electrical standards.
    Those are done at what are called FCC Labs.
    So each item sold in the US needs to have an FCC number.
    From that you can very often find service data that has to be submitted at the time of testing.
    Sneaky and nasty, but that is how it is in this business.
    Tried to look up the FCC ID Number.
    Could not even find the FCC number on this unit!
    I expect this on illegal cable boxes, CB Linear Amplifiers, and 'export radios'.
    Just wondering how this slipped by.
    Very weird.
    Be well all.
    Jack Crow
    "You are, what you do, when it counts"
    The Masso
    "Gravity, the quickest way down"
    Mayor John Almafi
    "You ever drop an egg, and on the floor you see it break?
    You go and get a mop so you can clean up your mistake.
    But did you ever stop to ponder why we know it's true?
    If you drop a broken egg you will not get an egg that's new?"
    MC Hawking
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Tivoli Audio Model One FCC ID issue
    You should post pictures of it, are you sure its not fake? I too am wondering what circuits make this thing sound good.
    -Ben
    Muh-soggy-knee
    • 999999999
      • Sep 2006
      • 774
      What is wrong with it that needs repaired?
      • Jack Crow
        It's a CLASOB!
        • May 2008
        • 823
        Guys,
        To answer your questions.
        Ben,
        Why it sounds good?
        The easy answer is the case is made with an internal ported speaker.
        It has bass and high end.
        Wider than standard AM filters and a very potent for a tiny box audio amp.
        It's the same kind of thing that makes other similar high end products sound good.
        Like the Bose wave radio.
        This unit is not cheap. They sell for about $150 each.
        That is real pricey for a table radio.
        The web photo is a clone of the unit I had on the desk.
        http://www.tivoliaudio.com/products/...campaign=m1cla
        Nines'
        The problem was weird. Yet that is the kind I tend to collect.
        The client complained about 'inter station noise' the crap we here when an analog tuner is adjusted across the dial. The radio lacks 'stereo muting' so all that FM crap oozes through until it detects a channel.
        Anyhow, I heard it make a god awful noise inter station noise in the clients home.
        It was so bad at first I thought the tuner was a veractor tuned device, and the tuning pot was dirty.
        When I cracked the case, this theory was a 'non starter'.
        There is a gear train similar to 'anti back lash' gears that connect the tuning knob to the shaft of what looks like a standard multi gang tuning cap of the type used in small portable radios.
        Anyhow, I get the radio home and the inter station noise seems to be normal, and not the screeching horror I heard at the clients home.
        So the problem is something in the house getting into the radio and not a radio defect.
        I looked it over, decided it is normal and will be returning it to the client.
        It is un ethical to fix what is not broken.
        That is the news.
        Jack Crow in VA
        The Masso
        Mayor John Almafi
        MC Hawking
        • Longbow
          • Jun 2011
          • 623
          I have some experience with these products. I can't say much about the FCC ID and never gave that topic a thought. They are cheaply made junk with a ported bass so they go boom boom. The typical consumer equates boom boom with high quality audio. Most of the problems in these radios have to do with loose connections caused by jamming in the 12 volt adaptor. That can be fixed, but working on the front end tuning characteristics is out of the question. Even if you had a schematic and some idea of what to look for you would have a very hard time getting it into a service position or finding suitable test points. The company that imports the things from abroad does not fix them or know anything about them. The schematics exist somewhere in China, Korea or India. Warranty replacement only. Similar to many other home entertainment offerings in that respect.
          Is it plugged in?
          • samson7point1@yahoo.com
            Help troubleshooting an audio problem with an RCA SGT-250 CED Player
            by samson7point1@yahoo.com
            The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
            The player processes the audio signal using two different reference frequencies. The "R"...
            04-30-2024, 11:22 AM
          • kurtspirit
            A2141 Jack audio issue
            by kurtspirit
            Good morning,
            I have a problem with a Macbook A2141 with the audio jack port. Sound only comes out from one side (left). The right one just emits a kind of crackling sound.
            I changed the jack ports twice to be sure that it was not caused by a defective part, but the result was the same.
            I have the impression that it could be an audio filter or component but I am unable to locate the affected part on the motherboard.
            Have you ever encountered a similar problem and can you help me find the filters, if they exist, on the map please?
            Thanks in advance...
            07-25-2024, 04:11 AM
          • 247
            Acer Swift Go 16 MODEL: N23C7 SFG16-71-771P USB/Audio Board wanted
            by 247
            I have a:
            Laptop (Acer Swift Go 16)
            MODEL: N23C7
            SFG16-71-771P
            I need to replace the USB/audio board but can't find it anywhere. I googled, used Goolge image search, nothing, not even on aliexpress.
            Do you know where else I can look for the part?
            05-31-2024, 03:53 AM
            Lenovo ThinkPad P43s Mobile workstation P Specification for Upgrade or Repair
            This specification for the Lenovo ThinkPad P43s Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P43s boardview and P43s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
            09-06-2024, 09:40 AM
