Ceramic resistor info required
  • garrymc123
    • Apr 2010
    • 336
    • United Kingdom
    Hi there i am looking for some advice. I am in the process of reparing a kam kka550 karaoke amp which had blew some transistors and also two ceramic resistors. What i wont to know is the value of the ceramic resistors i think it is
    5 watt 0.25 ohm but not sure because i cant find any anywhere i have tried maplin, rs components but no luck so hopefully some one can tell me if this is correct or not.
    thanks
    Garry
    Your never to old to learn
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Ceramic resistor info required
    You can use 0.22 ohms which is far more common.
    A working TV? How boring!
    • spleenharvester
      Ceramic capacitors/resistors - do suppliers matter?
      by spleenharvester
      I want to buy one of those SMD component books so I don't have to spend as much time searching my scrap boards for what I need, specifically ceramic caps and resistors as they seem to be what I spend most of my time replacing. But the only ones I can find are no name brands. Does manufacturer matter as much for SMD parts as it does with electrolytics or is the generic stuff likely to be fine?
      05-01-2025, 05:34 PM
    • ttmi100x
      HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
      by ttmi100x
      Greetings everyone,
      I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
      The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
      Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
      Upon closer inspection...
      07-31-2024, 06:36 PM
    • youpla
      PowerColor rx 5700xt dual fan : current sense resistor
      by youpla
      I’m repairing a PowerColor RX 5700 XT Dual Fan (not the Red Devil or Red Dragon model) with a burnt pin 5 on its 6-pin PCIe connector.
      The previous owner had it repaired by a shop. They soldered an enameled wire to reconnect pin 5 to the current sense resistor (shunt).
      The card wasn’t displaying anything after this fix.
      When I inspected their work, I found that the sense resistor had fallen off after reheating the solder joint (likely due to damaged pads from resistor).
      I tried to resolder it with a hot air station, but the resistor wouldn’t...
      Yesterday, 07:52 AM
    • TinkerTron
      Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
      by TinkerTron
      Hey everyone,
      I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
      Instead, here's what's been bugging me so far:
      The schematic...
      03-06-2025, 02:03 PM
    • artvandalai
      What resistor ohm will work better to repair this waterpik?
      by artvandalai
      The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
      01-05-2025, 04:10 PM
