Possibly Broken STR-AV310
  • RomoRock3r
    • May 2011
    Hello Everyone, I have an issue with my Sony STR-AV310. I think I fried mine . I would plug in my Sony Turntable to the PHONO jacks along with the ground wire to the ground screw and it would play well. Sometimes the buzzing would gradually get louder until it got so loud that the protection circuit goes on and an orange "P" would light up on the LCD. After I unplug the turntable, it goes back to normal. The last time I plugged it in, the buzzing got louder again until I heard a pop from the speakers. The receiver froze and it would not respond to the power button. Both the DBFB and Mute light was on and the LCD which said PHONO showed only parts of the letters lit. The "P" symbol didn't light. After a few seconds I saw a small amount of "Magic Smoke" coming from the receiver top. I quickly unplugged it after. I opened the top cover and looked for "fried" components. I didn't find any capacitors or resistors burnt or other burn marks on the PCB. The fuses near the transformer weren't blown. However I found the leads on what appears to be a Table Rectifier Diode burnt/charred. What I realized after is that the RCA plugs on the turntable seem to be frayed as when I plugged them into my computer, I also heard buzzing and crackling which was the same as I heard on the receiver before it broke. Is this receiver now completely broken? I have not plugged it back in because I am afraid I will damage it more. What I believe is that the shorted cables from the turntable caused too much power to be drawn from the rectifier and made it burn.
    If I replace that table rectifier diode will it work again? I have found similar table rectifier diodes online rated at 8A and 400V. Based on a spec sheet I found online, the Bridge Rectifier on the receiver is rated at 200V 4A. Can I replace the old bridge rectifier with the 8A 400V rated one?
    Here is where the broken part is:
    This is how the replacement part should look like:
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Possibly Broken STR-AV310
    Yes
    Mann-Made Global Warming.
    - Dr Seuss
    • chth96
      Is it possible bridging tiny broken trace
      by chth96
      When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
      cutting tiny trace.
      This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
      Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
      But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
      12-03-2022, 11:32 PM
    • CDNBrewer
      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
      by CDNBrewer
      Hello Everyone,
      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
      Symptoms:
      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
      • I swapped the Left and Right surround
      08-05-2025, 09:29 PM
    • wolf1976
      wireless receiver for 6 speeds fan control with remote control
      by wolf1976
      hi i have a receiver that is destroyed from the overvoltage i guess
      my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
      the motor fan has not label
      i have an other receiver operational
      In your opinion can i measure the voltage at the output ?
      what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
      thanks in advance...
      07-23-2025, 03:12 PM
    • Steph.hen
      Bridge rectifier identification part number KPB305G
      by Steph.hen
      Hi all, a newby question about a bridge rectifier I'm trying to identify.
      I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
      08-29-2024, 09:52 AM
    • Cornito
      Denon AVR-2700H audio stops while receiver still works
      by Cornito
      Hello team,
      I've got a new issue with a Denon Avr-2700H.
      After several minutes working, receiver stops playing sound with a poc eared in the speakers.
      Receiver still work and display video with error message on display.
      Seems to me that is the main output relay.
      I'm looking for the service manual that I can't find for the moment.
      Does somebody have it?
      Regards...
      08-03-2025, 06:10 AM
