(Car Audio) Alpine MRD-M1000 amp no errors, but no sound
  • torpex505
    replied
    Re: (Car Audio) Alpine MRD-M1000 amp no errors, but no sound
    Thanks, I'll try to get some pics tonight. It is definitely on the audio end. I am able to turn the amp on and even adjust settings through the optional "remote" mounted in the dash. I had another amp at one point that did the same thing and after re-soldering the RCA inputs it started working again. That was a cheap Jensen amp though. Being that this is a higher end amp, I didn't just want to start re-soldering anything without being sure.
    Also, any suggestions on how I can get a solid 12V to this thing on my workbench without running a set of jumper cables to my car battery?
    Thanks for you help
  • cadiman
    replied
    I had a couple of alpine amps but I never had to work on them. Car amps have a switching power supply driven by a modulation chip. This is half of any car amp.
    If you can verify the power supply is working you can move on to the audio end.
    Sometimes these run around 100v or more. Look for small mosfets on both sides
    If you have a scope there should be a 40khz signal feeding the mosfets to fire the inverter from the ic (14 or 16 pin). If I remember correctly the alpine amps were
    built very well. As for a car that sits I would go after board issues. I had an Alfasonic
    amp in my 65 Buick and I only drove it in the summer. I had the same problem you are
    having. I wasn`t getting the audio signal through the preamp. I had to crank up the input signal (1v) then It would start working. I re-soldered the preamp curcuits and that fixed it. Hot and cold ( worked on warm days) not in the morning.
    A picture would help alot here.
    good luck!
    Cadiman
  • (Car Audio) Alpine MRD-M1000 amp no errors, but no sound
    I just found that my Alpine MRD-M1000 amp is not putting out any sound.(I never use the car that it is in, so I have no idea when it went out) It is a Single-Channel (Sub) amp. When the amp is connected and on, I don't receive any error lights, there is just no sound coming out. I thought it may be faulty RCAs or speaker wire, but I swapped a different amp in it's place and everything works as it should. I opened the back panel, and everything looks to be ok. Any advice on what I should start checking?
  • i_am_patch
    Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
    by i_am_patch
    Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
    04-30-2024, 08:20 PM
  • Piaskos
    Dell Vostro 5490 - no sound, no audio device
    by Piaskos
    Hi, i've got problem with Dell Vostro 5490.
    Board - Mantis CML 18788-1
    Windows says "no audio device detected". The other functions work properly.
    What i've done:
    1. I checked motherboard
    2. I changed audio codec (ALC3204)
    3. I reflashed bios with clear ME
    4. Audio is enable in bios
    5. Both speakers are good
    6. After installing the drivers from the Dell website, the devices visible in the manager:
    - Audio for intel displays
    - Intel Smart Sound Technology...
    01-30-2023, 02:58 AM
  • ChaosLegionnaire
    by ChaosLegionnaire
    09-13-2022, 09:02 AM
  • CapLeaker
    Motorola Minitor V pager no audio / sound repair
    by CapLeaker
    Got a bunch of Motorola Minitor V pagers from Fire Departments here trying to fix some out of the non working ones. These pagers are known for either no sound / audio or they don’t charge. The internet is full of suggestions like metal shavings inside the speaker?
    Anyway so I took one of the Minitor’s apart for my amusement in order to see why that is and nobody can fix em. There are no service manuals or schematics for these that I know of. However… I did find the problem!
    On the main board of this unit where the speaker connects to there is a metal shield....
    06-10-2025, 07:44 PM
  • JRade
    Audio video receiver KENWood KR-V990D,no sound
    by JRade
    When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
    The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
    I replaced the capacitor C303/0.047F, nothing changes.
    I'm asking for help, what should I do next?
    Thanks in advance!...
    08-05-2025, 10:23 PM
