Hello, can you help me with the schematic for this boombox. I found some information, but without schematic things look weird.
Sony gtk-xb7 40BHX2240-MAH2G
by momakaIs a mid-2000’s boombox worthless? - I’d say probably yes
or at least certainly a candidate for this thread:
https://www.badcaps.net/forum/showth...post+worthless
Long story long
, my dad picked up a Sony CFD-E55 boombox over a decade ago from the trash room in a condo where we used to live.
(Note: picture below is of the boombox after the repair.)
He then put it in a box when we moved places and it sat in the garage for a few years. Eventually, I tested the boombox and found that it worked on batteries, but not on...-
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
by dkneyleDiagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about... -
This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 05:27 AM
by retrorepair2Hi all,
I've got the above tv and it's displaying the strangest issue I think I've seen (see attached).
The TVs backlight does what I'd expect, you can hear the menu when it boots up, but the display is the same garbled mess regardless what it's doing.
Does anyone have any ideas where to start? My gut says main board but maybe tcon?
More often than not, the blocks have straight edges and the pattern you see on the picture that overlays the white and green moves out from the middle up and down. I can upload a video if it helps... - Loading...
