Yamaha XP7000 Crackling in left channel
  • xfreakx
    • Mar 2023
    • 3
    • Croatia
    Hi guys,
    I have a problem with the power amplifier Yamaha XP700, I hope someone can help or point me in a direction.
    The amp started occasionally to crackle in the left channel which in a short time period got more frequent and after a while the crackling occurred instantly on power on.
    While checking for loose connections the amp's protection kicked in and turned the amp off. From then the protection turned the amp off in between 1 - 5 seconds after power on.
    I switched the mono blocks for a test to make sure the error is in the block itself and not maybe in the input module or power supply.
    Removed the heatsink and found some burnt out components (Q207, R216 and R224. Replaced them. Protection doesn't kick in anymore but the crackling is still there.
    Replaced for a test the 3 audio caps (C225, C211, C213), Q205 and also the op-amp IC201 without any result.
    Can someone help?
    * (Besides a digital multimeter I don't own any equipment so my possibilities are quite limited.)
  • petehall347
    • Jan 2015
    • 4437
    • United Kingdom
    Re: Yamaha XP7000 Crackling in left channel
    you could try heating and cooling different areas .
    • xfreakx
      • Mar 2023
      • 3
      • Croatia
      Yeah I was also thinking on that but I'm a bit worried I might burn again the protection circuit components if I turn the amp on for longer than a few seconds and since the crackling occurs instantly, it doesn't look to me like a thermal related issue.
      I have also removed the heatsink to be able to access the board from the bottom and I don't know how long I can run the block without to destroy the output transistors.
      • petehall347
        • Jan 2015
        • 4437
        • United Kingdom
        you cant run it even for less than a second without the heatsinks as it will destroy the transistors
        • petehall347
          • Jan 2015
          • 4437
          • United Kingdom
          check the transistor numbers against lists of known noisy ones
          • HelpMeRepair
            Yamaha RX-A3010 left channel no signal
            by HelpMeRepair
            Hi everyone , I have a rx-A3010 that all alllll the channel working except of Front left , if someone can lead me on what to begin wit it would be very helpful
            what I did so far ,
            factory reset
            test all other channel
            tone test
            dissasemble and look , visual inspection witout full dissasembly
            looked at all the mosfet for temperature to see if they eas operating
            scratch my head couple of time
            thanks in advance all help is appreciated , service manual are welcome too ! =)...
            11-14-2024, 02:48 PM
          • Sik_6ty_Sixx
            HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
            by Sik_6ty_Sixx
            So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
            02-18-2025, 05:06 AM
          • karatzdi
            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
            by karatzdi
            I know some might say... just buy another one. Sell it as parts..!
            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
            Spent some time downloading the Service...
            06-11-2024, 08:38 AM
          • eccerr0r
            old X58 triple channel board... memtest86 memory speed?
            by eccerr0r
            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
            06-28-2025, 09:06 AM
          • CDNBrewer
            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
            by CDNBrewer
            Hello Everyone,
            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
            Symptoms:
            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
            • I swapped the Left and Right surround
            08-05-2025, 09:29 PM
