GE PFS22SISSS Refrigerator - Not cooling
  • ceconomon
    • Oct 2011
    • 67
    And so I venture from TV's to appliances...haven't found a TV to work on in a while.
    I helped out a friend that had a refrigerator that was cooling. He had a repairman condemn the unit and I figured I had nothing to lose but an hour or two doing something I enjoy.
    The unit had power (lights) but nothing else was going on. The repairman had told him the mainboard needed to be replaced. I removed the board and inspected it for problems. As you can see problems were pretty obvious.
    2 bad 400v 47uf cap - bulging domes
    and one Offline IC switch (whatever that is)- I'm glad there was enough of the part number left on it to track it down.
    $12 in parts were replaced and I'm not getting a clicking noise next to the compressor along with internal fans. Compound problems are always fun. I'm able to find this is a common problem and the replace the relay (Relay Overload Starter). The unit starts up and is cooling. After testing for a few hours, I notice the evaporator fan hasn't been on the entire time...it's dead too. That will be replaced later this week..the benefit of this unit being in a vacant rental.
    It's nice to return a condemned unit to service for ~$100.
  • dragos2009
    • Mar 2013
    • 110
    • Romania
    Re: GE PFS22SISSS Refrigerator - Not cooling
    in that picture i see 2 badcaps on the back of the transformer near that black heatsink
    • delaware74b
      • Apr 2009
      • 628
      The evaporator fan motor is what causes the damage to GE's refrigerator motherboards. It is a very common problem. GE's side by side refrigerators are so bad they had Lg or Samsung make refrigerators for them. Electrolux is buying all of GE's Appliance division.
      Judging from the few caps in that picture, I see a complete re-cap if you are planning to keep that refrigerator for a couple more years. FYI - they also have problems with the thermistors in both the fresh food and freezer sections.
      A little reading in this appliance forum I visit:
      http://www.applianceblog.com/mainfor...5-GE-Hotpoint?
      Stupidity should be a crime, especially for drivers. I have NO patience for them.
      • ceconomon
        • Oct 2011
        • 67
        The evaporator fan motor tested good with a battery. I ended up re-caping most of the board to get the fan to run.
        It seems like most of the brands have complaints about them. I have a GE Profile that the water line in the door freezes up. If it was under warranty, they would replace the doors. The insulation deteriorates and the doors are glued together so there is no "nice" way to fix it. I found a post where someone taped foam insulation board to fix the problem...I only deal with the problem about once a year with this in place.
        waiting for my next project to show up......
        • Th3_uN1Qu3
          Cooling upgrade on refrigerator. If it works, it ain't stupid!
          by Th3_uN1Qu3
          I had this refrigerator at my old folks which I noticed I would put my beer or soda in and take it out warmer than I'd brought it from the store.
          Now, I don't know much about refrigerators or HVAC but to me it seemed like we have a problem. I threw a thermometer in... 20 deg C in the fridge. WHAT THE... Freezer worked fine with temperatures way below zero, as it should, and it has only one compressor for both sides so it got me scratching my head for a while.
          Only other things that seemed a bit odd was that the heatsink on the back was barely warm and the...
          09-03-2023, 06:29 AM
        • Ace Perception
          Samsung R530 Bremen motherboard cooling
          by Ace Perception
          I'm wondering if anybody out there has much knowledge of Samsung Bremen motherboards.
          I've got a Samsung R530 which is about 10 years old, over the last 12 months it developed a worsening problem where when asked to do much work it would shut itself down. I had a good idea this was due to overheating which was confirmed by a temperature monitor programme which showed little balls of fire next to the various internal temperature readings. I could also prevent it shutting down if I placed a huge fan running at full speed in front of its air intake!
          So I went in pursuit of...
          07-21-2020, 03:05 PM
        • ngml
          Repair of an LG split AC system indoor unit PCB
          by ngml
          I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
          This indicates an error in the communication between the outdoor and the indoor unit.
          The outdoor unit is fine, so the problem is the indoor PCB.
          The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
          I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
          Does anybody have the schematics of this board,...
          02-01-2025, 12:55 PM
        • jean luc ferre
          laptop hp g72 b52sf screen problems
          by jean luc ferre
          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
          06-07-2025, 03:27 PM
        • Hondaman
          Liquid cooling?
          by Hondaman
          I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
          (After previous generation hardware [Gigabyte] didn't...
          05-08-2025, 09:37 PM
