Masina de spalat ,are aprox 7 ani,a functionat perfect pana acum .De o saptamana insa ,sare programul de stoarcere.Am curatat filtrul pompei de apa,am verificat daca paleta pompei de apa se invarte usor,daca rezistenta de incalzire este in regula,daca evacuarea apei din cuva se face corespunzator.Toate sunt in regula.Am selectat programul '''Rinse+Spin cu durata de 18 min.Masina a functionat corect pana in min 9,sarind la min 1 ,oprindu se dupa aceea,deci sarind peste programul de stoarcere.Va rog ,date cele relatate ce este de facut.? Banuiesc ca ar putea fi softul corupt si ce ar fi de facut daca ar fi asa.Va rog, sa mi dati sugestii cu ce este de facut in legatura cu acest subiect.Multumesc anticipat !
Samsung Eco Bubble VRT plus 12.0 kg
Here is a translation from Romanian into English using Google translate:
The washing machine is approximately 7 years old, it has worked perfectly until now. For a week, however, the spin program skips. I cleaned the water pump filter, I checked if the water pump paddle rotates easily, if the heating resistance is OK if the water is drained from the tub properly. Everything is fine. I selected the "Rinse+Spin" program with a duration of 18 min. The machine worked correctly until 9, skipping to min 1, stopping after that, so skipping the squeezing program. Please, given the information, what is to be done? I suspect that the software could be corrupted and what would be done if it were so. Please, give me suggestions on what to do about this subject. Thank you in advance!
It is washing but the spin cycle isn't working? Maybe the shock absorbers on the drum are bad? Apparently it will kill the spin cycle for this reason as the vibration sensor kicks in. Also check the door lock switch. Are there any error codes?
If there was an issue with the pump like a clog or something, the wash machine needs re calibration.
You can force a spin only cycle.
Try this: https://www.youtube.com/watch?v=Ovok2WYMNxULast edited by CapLeaker; 11-28-2024, 02:00 PM. -
Salut ! Amortizoarele sunt in regula,de asemenea si comutatorul de blocare al usii ,pe ecran nu apare nicio eroare.Inteleg logica dumneavoastra doar ca masina nu incepe sa stoarca la nivelul in care sa inceapa sa zdruncine astfel incat sa intre senzorul de vibratii in functiune.tentativa de centrifugare se face lent,si dureaza foarte putin,sarind de la minutul 9 la 1.Oricum,multumesc pentru interes.Mai astept sugestii !Comment
If there is a fault that occurs, it is supposed to play a melody song and display a fault code.
Where is the display fault code? i.e. "UB" unbalanced load, or "LC1" water leakage etc.
I thought it will terminate a spin cycle early- if the vibration is too much shaking. The machine must be on a level surface.
Or the water-level or water leakage sensor are triggering. Check the the drum air hose did not fall off, then it will leak water only during spin/squeezing.
Samsung service manuals are terrible junk. They don't tell you what the machine logic or reasoning is.
I found this Samsung Front-load Washer service manual, includes some Eco Bubble. I am not sure what OP's model number is.
Looking at the sensors:
Door Open and door open safety check.
Water-level sensor, that is a pressure sensor hose usually plugs.
Water-leakage sensor
Three temperature sensors?
Optional sensors:
Vibration MEMS sensor
Add Wash door open switch
Turbidity sensorAttached Filesif you find these attachements useful please consider making a small donation to the site
Translates to this:Salut ! Amortizoarele sunt in regula,de asemenea si comutatorul de blocare al usii ,pe ecran nu apare nicio eroare.Inteleg logica dumneavoastra doar ca masina nu incepe sa stoarca la nivelul in care sa inceapa sa zdruncine astfel incat sa intre senzorul de vibratii in functiune.tentativa de centrifugare se face lent,si dureaza foarte putin,sarind de la minutul 9 la 1.Oricum,multumesc pentru interes.Mai astept sugestii !
Hello! The shock absorbers are fine, as well as the door lock switch, no error appears on the screen. I understand your logic only that the car does not start to squeeze to the level where it starts to shake so that the vibration sensor comes into operation. the attempt of centrifugation is slow, and lasts very little, jumping from minute 9 to minute 1. Anyway, thank you for your interest. I'm still waiting for suggestions!
I am not really good with Samsung washer and dryers, but on other overseas appliances like Miele, AEG, Bosch, etc I came once across an older washer with no spin cycle due to a bad relay.
Did you try to force a spin cycle by pressing the spin button?Comment
Translation:
Hello friends! I'm going to try to buy the motor inverter module. A friend with experience in washing machines is almost certain that's where the problem is. Where can I find this module?
either you find a whole replacement board at a dealer, eBay etc. or you buy the IC by itself and swap it out on the board. Try suppliers, like Mouser, Digikey, LCSC, TME, Ailiexpress…Comment
by ivanwx2000hl colegas les comparto este archivo funcional EC
English - Dear colleagues, I share this functional EC file with you....-
Channel: BIOS Requests ONLY!
07-23-2025, 08:08 AM -
by Axel ValdesAyuda no arranca macbook a1466
solo me quedo este archibo...-
Channel: Announcements & Related News
by 220vdcHi, Is this Memory (see bubble)damaged?
Legion 5pro ... -
by tantr13Hi everyone,
This is my first post so I'm hoping to get some help on this awesome forum. As a preface, I'm an amateur at electronics, especially troubleshooting complicated devices like laptops. However, I'm trying to develop a skill for it so I can learn how these devices work and how to repair them without continuing the wasteful tradition of throwing them away and buying new. 🤮
I've had a Lenovo Ideapad 5 14ITL05 for a few years now, with motherboard LA-K321P. I would never leave it plugged in unless I was using it, and always turned it off after I was done, but last week... -
by AstrayHello, working on a laptop (MSI GS75 9SG-242US, Core i7-9750H, 2080 Max Q) and after replacing the screen and forgetting to disconnect the battery prior, I have no visible indications of power anywhere. It was working perfectly fine prior to the screen removal and replacement. Checked the motherboard PCB visually near the LCD connectors and didn't really see any indications of damaged surface mounted components but haven't looked under a microscope yet.
Battery charging light isn't turning on when plugged in and pressing the button does nothing regardless of being on battery power... - Loading...
