LG fridge compressor not starting
  • unimatrix93
    • Oct 2021
    • 360
    • Magyarország
    I disassembled the froster to get to the temperature sensor and fuse.
    Turns out both of them are good.
    I decided to re check the main power board.
    Turns out I made a soldering mistake at the heaters relay,(I replaced all of the relays to new ones) one of the coils leg were not soldered properly.
    So I resoldered it and reassembled it into the fridge and the error is gone. The compressor is working and the fridge is cooling too. I wait until monday to test it before I completely reassemble it.
    And I will return with the reports.
    Thank you all and wish me luck please!
      • Jul 2011
      • 6070
      Bad soldering trace joints will get you every time what is that relay powering the hole circuit for the compressor or just part of it
      or was it just for the heater for defrost circuit that would explain the defrost error message that you were getting
      Do not run the refrigerator very long if you have the panel for the evaporator coil off because you could damage the compressor if you were to run it that way for a long time
      Make sure that the controller board is functioning correctly and you do not have any other issues like the display not coming on correctly or not going into defrost every so often it might be every 6 or 8 hours depending on how it is programmed
      • Liam.25
        Beko fridge compressor clicking
        by Liam.25
        our fridge and freezer stopped cooling last weekend, it’s a Beko fridge.
        looking at the bottom, I can hear the relay clicking on the plug attached to the compressor.
        There is also a 3uf capacitor, I’m thinking this is a run capacitor, I tested this with my fluke and and it measured at 1.5uf, so I replaced this (new one tested just over 3uf) so that’s where it should be.
        I was thinking this was the issue. The compressor seem to run for like a minute then shutoff again.
        inside the relay, there is a Klixon 4tm thermistor,...
        03-23-2024, 07:42 AM
      • CoinCoin88
        Garage door RX unit (Cardin S38C) does not short relay to send opening signal
        by CoinCoin88
        I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
        Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
        09-15-2025, 03:36 AM
      • mikey5791
        Help repair Panasonic fridge not cooling
        by mikey5791
        Hi all forum members,
        Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
        After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
        07-16-2025, 02:01 AM
      • mon2
        bad linear compressor on my LG fridge
        by mon2
        Singing the blues with a bad linear compressor on my LG fridge so the house is in turmoil. LG was apparently sued over the '10 year warranty' that we fell for as the best in the market but then they want to charge (locally) ~$700 CAD to install the new 'under warranty' compressor. After major complaining about ethics, they may be granting us a service favor @ ~$250 (CAD) for the same service. Spoiled food and no fridge. Fun times.
        12-29-2021, 09:28 PM
      • CG2
        Liebherr Fridge Freezer KGT 3456 not working
        by CG2
        To be a bit more specific, I've got a 20-ish year old Liebherr that has just stopped working. This was quite a sophisticated beast for its time. It's a twin compressor model, and you set the desired temperatures of the fridge and freezer parts from a couple of little control panels above the door. It displays the actual temps on some eight segment displays there, flashing if it's working to get to where you want it. There's a control board with a microprocessor on it that read the temperature from a couple of sensors, switches the compressors on as necessary, and runs the display. There's also...
        01-25-2023, 02:12 PM
