Honda. 31570-VP7-A01
  • omgitdrifty
    • Aug 2024
    • 16
    • United Kingdom
    Hi guys
    Got a Honda. 31570-VP7-A01 mother board here with a K0CA 7A fuse.
    I cant find this fuse.
    Question is what can I replace it with.. I know it AC 7 AMP fuse but what does K0 stand for?
    Click image for larger version  Name:	WIN_20240906_08_40_58_Pro.jpg Views:	0 Size:	261.7 KB ID:	3345510
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Normal Blow Fuse
      • 31086
      KOAC is the brand
      https://www.koaglobal.com/
      • omgitdrifty
        • Aug 2024
        • 16
        • United Kingdom
        ok so I replace fuse check for short no short. plug in and boom the fuse blown again. so i checked again finding nothing, no issue no shorts no other blown component and since there is no short I can't inject volt.
        so what me next move?
          • 31086
          show more of the board.
          you probably have a large transistor or driver chip with something shorted on it's output.
          • omgitdrifty
            • Aug 2024
            • 16
            • United Kingdom
            Hi here picture of both side of the board
            thanks David
            • petehall347
              • Jan 2015
              • 4427
              • United Kingdom
              clean anything that's square and black to get a better look .
                • 31086
                check the ceramic capacitors and large 3pin parts for shorts.
                hopefully it wont be that big driver chip with the heatsink tab under it!
                what is this anyway, a 3phase motor driver?
                • omgitdrifty
                  • Aug 2024
                  • 16
                  • United Kingdom
                  it for the docking station for a lawn morrow.
                  I found the issue, Like I said there nothing wrong with the board no shorts it blow because of incorrect volt.
                  250v was incorrect it meant to be 120 volt.
                  • petehall347
                    • Jan 2015
                    • 4427
                    • United Kingdom
                    that would do it
                      • 31086
                      your lucky it only did the fuse!
                      • omgitdrifty
                        • Aug 2024
                        • 16
                        • United Kingdom
                        yeh I told the guy he was lucky I also said WTF when he told me he just plug it in the main socket lol
                        • corrize
                          A funny fuse story – Lumix LX100 II
                          by corrize
                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                          10-19-2023, 09:58 AM
                        • DXseekerMO
                          Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
                          by DXseekerMO
                          Hello everyone!
                          Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
                          Symptoms:
                          1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
                          2) TV does not appear to turn on
                          3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
                          4) "Power on" terminal on Power Supply has 3.26v
                          5) "A13V" terminals have 12.9v
                          6) Stand-by test jumper on Power Supply has 12.9V
                          7) Optical audio jack on Main Board illuminates
                          8) With stand-by...
                          06-09-2021, 12:19 AM
                        • jesterace
                          Samsung UE46ES8000 Blown fuse but no other signs of short
                          by jesterace
                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                          09-11-2024, 03:14 PM
                        • jshhh
                          Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                          by jshhh
                          Hi guys,
                          I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                          How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                          Anybody know how to remove this type of fuse?
                          (The fuse is toward the bottom of the image labeled F2)...
                          06-17-2025, 01:35 AM
                        • Babbar
                          by Babbar
                          04-12-2024, 01:12 AM
