BLUETTI EB3A
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    BLUETTI EB3A
    My charging station stopped working. It charges and the flashlight works, but if I turn on the DC output, it stops working! Does anyone have any diagrams and what could it be?
  • CapLeaker
    Leaking Member
    • 7999
    Open it up… maybe there is a fuse somewhere inside?
    • PITERPENY
      • Jul 2023
      • 455
      • Ukraine
      nothing unusual. the problem comes from the board on the front side. what to look for?
      • CapLeaker
        Leaking Member
        • 7999
        The display complains about a short on the DC side. Verify it with your DMM. Maybe a diode went bust. Make a straight shot, high resolution picture of the board with the display. I wonder if there is a DC to DC converter or something. Start measuring at the DC output terminals and work your way towards the input and look for a short or open.
        You probably have multiple DC outputs, so you have to look at each one to see which one it is. Once you remove the short, all other DC outputs should be working ok again. The lamp is a separate DC circuit.
          • Jul 2011
          • 6024
          Or start at the switch that turns on the dc voltage and see where it hooks to the board and work backwards to where you find a short
          One note the BMS board is a little bit weird because it has a connector where the mosfets are I have not seen this kind-a setup before I am curious to where this connection to the next board and what it does and what it tells the main controller board
          I have one of these type power pack and I have thought about taking it apart and putting a much bigger battery pack in it externally and now seeing what is in one I going to give it a try and see what happens
            • 30937
            i have seen one company that has a docking connector on the top and bottom,
            you can stack battery units or invertor units to create a tower!
              • Jul 2011
              • 6024
              If you can remember what company has this feature can you please share it
                • 30937
                https://inergytek.com/
                • PITERPENY
                  • Jul 2023
                  • 455
                  • Ukraine
                  ECOFLOW
                  • PITERPENY
                    • Jul 2023
                    • 455
                    • Ukraine
                    Later I will disassemble the station for a photo in high resolution. And now a video and photo of the error.
                    • CapLeaker
                      Leaking Member
                      • 7999
                      before you do that, measure each DC output with your DMM for voltage output and a short. Going to be annoying because you have to restart the unit every time so it doesn't know yet it has a short.
                      • PITERPENY
                        • Jul 2023
                        • 455
                        • Ukraine
                        BLUETTI sent me updates and I updated the station and now it charges and everything works except AC. There are no errors. AC just does not turn on either from the button or from the app!
                        the judge from all problems with the inverter which BLUETTI blocked in the transferred firmware.​
                          • Jul 2011
                          • 6024
                          I have to wonder about how and why the firmware got corrupte like that and apparently even with the firmware update it still did not fix everything I have one very similar and my son has one as well this is the reason I took interest in this post
                          I am not very confident about the longevity of this device and I was even thinking about buying another now I might have to reconsider this idea
                          • PITERPENY
                            • Jul 2023
                            • 455
                            • Ukraine
                            I don't think it's worth changing the station. After watching a lot of video services, it turned out that this is a banal problem of battery imbalance due to a weak BMS. If the station is not used constantly, then there should be no problems. With frequent use of the station, the lithiumferum elements are charged unevenly, which is why this error appears! The treatment turned out to be simple! After updating to the latest BMS firmware, the DS port immediately started working! But for the AC, I had to wait 12 hours for the charge to evenly charge all the elements!
                            • PITERPENY
                              • Jul 2023
                              • 455
                              • Ukraine
                              • PITERPENY
                                • Jul 2023
                                • 455
                                • Ukraine
                                • PITERPENY
                                  • Jul 2023
                                  • 455
                                  • Ukraine
                                  advice if you have problems with the BLUETTI station write to them by email. The BLUETTI team was always in touch and responded very quickly. I did not have updates for the station. They asked for my serial number and said that they would add it to the list for an emergency update. After which 2 updates immediately appeared in my application. Which led to a complete cure of the station and it is now fully functional. THANKS TO THE BLUETTI TEAM!
                                  • CapLeaker
                                    Leaking Member
                                    • 7999
                                    Interesting. So the BMS cut off the batteries for the DC section. At least you were able to fix it.
                                      • Jul 2011
                                      • 6024
                                      BMS protection board do function this way but most of them when you reapply power to charge them if you do not have the over current or short condition anymore it reset this might have been done purposely to prevent it self from being destroyed by self destruction
                                      One note about the video that was showing that the battery cells were unbalanced yes you can try to rebalance them but if they are suffering from self discharging sin drum there is nothing you can do about that you just have to replace the battery cells with new ones then use a battery balancing device that was shown in that video
                                      One other note about the other video about the inverted locking out the controller board and not being able to resetting the controller unless you disconnect the controller cable between the inverter and controller board I am not sure what to make of this situation unless it is for the reason I mentioned above in the beginning of this post
                                        • Jul 2011
                                        • 6024
                                        It is good that the company responded to your concerns about there product having issues but having to do a firmware update and this resolving your issue is great but I have to wonder if after this device came on market that they realized that was an issue with their product having unrecoverable issues and need a firmware update to fix this issue interesting situation
                                          HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-12-2024, 02:20 PM
                                          MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook GF Specification for Upgrade or Repair
                                          This specification for the MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF66 11UG-820FR Katana Dragon Station boardview and GF66 11UG-820FR Katana Dragon Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-07-2024, 05:20 AM
                                          HP EliteBook 840 G6 + UltraSlim Docking Station Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G6 + UltraSlim Docking Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + UltraSlim Docking Station boardview and 840 G6 + UltraSlim Docking Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-06-2024, 06:00 PM
                                          09-06-2024, 12:30 PM
                                          HP ProBook 640 G5 + UltraSlim Docking Station Notebook 600 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 640 G5 + UltraSlim Docking Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G5 + UltraSlim Docking Station boardview and 640 G5 + UltraSlim Docking Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-06-2024, 10:56 AM
