Umm… if you shorted that TVS and the thing works, then there can't be a bidirectional voltage protection device in there. This “device” is going from the positive from one cap to positive to the other cap? I think we should have pics from top and bottom on the first go around. It just doesn't make any sense to me to have one supply, go into a cap, then use a fuse and go into another cap. For what? What does the second cap power? Maybe post some straight shot pics from top and bottom, to see what's going on here.
Garage door module Nice SNA4/A - burnt component
It's not an easy PCB to trace out.
Polarity is not making sense if (- from the rectifier) goes to that connector outside pin. Is it reversed with "+50VDC from rectifier pin"? Are you sure that's right?
Which is (+) and (-) on the 63V 2,200uF cap by the 100k resistor? And the 63V 1,000uF.
So far it looks like a blocking diode, one end (cathode?) facing connector trace goes up to the relays. That would mean it's a battery isolator diode.
Where does the battery connect? I guess the 2-pin grey connector bottom right.Comment
I forgot to mention, all the caps have their negative oriented towards the 5-pin connector and their positives towards the gray plastic connectors.
That 5-pin connector is probably for battery, but i'm not using battery, so I'm not sure.
I'm pretty sure about the 0/- being the outside pin on the large connector, because all the caps negative poles are connected to it.
As to how difficult this is to read, I'm barely making things out and I'm holding the board. I have no idea how you guys can make sense of this using pictures.Comment
Light bulb is connected to 2 of the 4 separated pins where that longer relay is. I commented on the polarity of the caps above.
all the caps have their negative oriented towards the 5-pin connector and their positives towards the gray plastic connectors.Comment
What you call "- from rectifier" connector pin the PCB trace goes to the capacitor pins away from the 5-pin connector (+)?. So I think that is not right.
Anyhow... the mystery part is in series with DC power to the relays (motor). That makes it an ordinary diode. The purpose might be to prevent backfeed/regeneration into the DC power if the door/gate moves on its own. A DC motor can act like a generator if you spin it, and a moving door or gate can do that. Sorry I was wrong about a GDT or TVS, whatever I said earlier.
Original might then be a cooked MR756 diode. A replacement (plastic) diode would be 6A02 thru 6A10 (for 6A) or a big fat 10A02 thru 10A10 (for 10A) same size leads. Cathode band towards the relays. I think a 6A part at 200-600V is strong enough.Comment
Well, spoke to soon. Sometimes the board comes alive (even with 31V bench power supply), but most often it won't. I cannot find out why. I tried to heat the board up from down below, but it didn't make any difference.
The power supply shows few mA for a moment, but then it goes into 0mA, so nothing seems shorted. The 1st 2 caps (around that burnt diode) get charged, but nothing else does.
I cannot work out how the rest of the board should get powered. Neither of the 2 DC-DC chips have any power either.Comment
The new diode might be in backwards if I gave more bad advice? Cathode is away from the relays eek if "- from rectifier" is right in your drawings. If the pad has lifted off, you can use other pad, put it there like pic.
The fuse is good and has power? Check the TO-220 below it and the big resistors. Can you read any numbers on the TO-220 parts?
This supposed to be a 24VDC board but has 50V coming in? Must be a buck converter from 50V to 24V, the heatsink by the 24V relay below?
There are two buck-converters that have the blue inductors "101". If there is no power there, then look upstream.
I think it goes 50V raw in -> 24V ->12V -> 5V. This board is a bit crazy.Comment
Found the issue, it was right between the chair and the desk. Mistake on mistake, but I did figure it out. I was tracing why those other caps don't have any voltage and it turns out there is another lower-voltage supply on the 3rd pin on that big connector. I was going off of my memory since I got back to looking into this, so that's what I didn't remember. The cases when I was able to make the board come alive must have been when I accidentally connected my power supply to that 3rd pin I guess.
What i don't understand is that voltage supply on 3rd pin comes directly from transformer (so bypasses rectifier) and when I measure it it shows 25VAC, but when I switched my multimeter to DC, it shows 7.5VDC.Comment
by sam_sam_samI had a lot of trouble with the WiFi connection from my router inside of the house into a ( new ) metal garage I had to run a 150 ft cat6 patch cord so the WIFI connection would be strong enough for the WiFi connection on the garage door opener would work correctly ( my son has a work out area in the garage as well and he was having to put his phone near the door to be able to stream music ) ( so I was going to eventually put WiFi out there anyway )
This garage door opener WiFi is very touchy if you lose the power it does not remember the password for the router which is weird or... -
by sam_sam_samI have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
by sam_sam_samThis happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
I am comparing them to a brand new one that I installed
The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
I going to let it run for several days before I remount back on the wall next to the... -
by sam_sam_samI was having issues with the controller not always responding to remote control signal having to hold button until garage door started to move
Now after replacing the two capacitors on the two 5 volt power supply rails
One is used for the up/down limit up/down force circuits
Second one is used for the radio receiver circuit
The main filtering capacitor ESR value was a little higher than a new one
https://www.northshorecommercialdoor...yABEgLxlvD_BwE
First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheetHi all,
I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if... - Loading...
