Garage door module Nice SNA4/A - burnt component
  • CapLeaker
    Leaking Member
    • 8214
    Umm… if you shorted that TVS and the thing works, then there can't be a bidirectional voltage protection device in there. This “device” is going from the positive from one cap to positive to the other cap? I think we should have pics from top and bottom on the first go around. It just doesn't make any sense to me to have one supply, go into a cap, then use a fuse and go into another cap. For what? What does the second cap power? Maybe post some straight shot pics from top and bottom, to see what's going on here.
    • jm1234
      • Jan 2024
      • 61
      • Slovakia
ID:	3494136 Click image for larger version
ID:	3494137I had an older picture without the caps, should be easier to trace.
      • jm1234
        • Jan 2024
        • 61
        • Slovakia
        The bottom picture shows bi-di TDS soldered. One pad is missing, but it is indeed soldered on the other side of the board.
        • redwire
          • 3910
          It's not an easy PCB to trace out.
          Polarity is not making sense if (- from the rectifier) goes to that connector outside pin. Is it reversed with "+50VDC from rectifier pin"? Are you sure that's right?
          Which is (+) and (-) on the 63V 2,200uF cap by the 100k resistor? And the 63V 1,000uF.
          So far it looks like a blocking diode, one end (cathode?) facing connector trace goes up to the relays. That would mean it's a battery isolator diode.
          Where does the battery connect? I guess the 2-pin grey connector bottom right.
          • jm1234
            • Jan 2024
            • 61
            • Slovakia
            I forgot to mention, all the caps have their negative oriented towards the 5-pin connector and their positives towards the gray plastic connectors.
            That 5-pin connector is probably for battery, but i'm not using battery, so I'm not sure.
            I'm pretty sure about the 0/- being the outside pin on the large connector, because all the caps negative poles are connected to it.
            As to how difficult this is to read, I'm barely making things out and I'm holding the board. I have no idea how you guys can make sense of this using pictures.
            • jm1234
              • Jan 2024
              • 61
              • Slovakia
              #26
              The grey plastic connectors are NOT for battery, I'm pretty sure about that.They are for start/stop and other commands. Like I wrote above, I think battery is meant to be connected to the 5-pin connector.
              • redwire
                • 3910
                OK that connector has high current thick PCB traces, but it seems to be for a lightbulb. Battery option is some small 1.2Ah with built-in charger.
                Just need the polarity of the caps to figure this out.
                • jm1234
                  • Jan 2024
                  • 61
                  • Slovakia
                  #28
                  Light bulb is connected to 2 of the 4 separated pins where that longer relay is. I commented on the polarity of the caps above.
                  • redwire
                    • 3910
                    What you call "- from rectifier" connector pin the PCB trace goes to the capacitor pins away from the 5-pin connector (+)?. So I think that is not right.
                    Anyhow... the mystery part is in series with DC power to the relays (motor). That makes it an ordinary diode. The purpose might be to prevent backfeed/regeneration into the DC power if the door/gate moves on its own. A DC motor can act like a generator if you spin it, and a moving door or gate can do that. Sorry I was wrong about a GDT or TVS, whatever I said earlier.
                    Original might then be a cooked MR756 diode. A replacement (plastic) diode would be 6A02 thru 6A10 (for 6A) or a big fat 10A02 thru 10A10 (for 10A) same size leads. Cathode band towards the relays. I think a 6A part at 200-600V is strong enough.
                    • jm1234
                      • Jan 2024
                      • 61
                      • Slovakia
                      #30
                      I'm so grateful to both you guys redwire and CapLeaker, thanks a lot!
                      • CapLeaker
                        Leaking Member
                        • 8214
                        We should have had the second pictures you took first place around. I agree with redwire, that device is just a blocker diode. It's starting making sense now being able to see the full top and bottom. Pictures are important, as you can see…
                        • jm1234
                          • Jan 2024
                          • 61
                          • Slovakia
                          #32
                          Well, spoke to soon. Sometimes the board comes alive (even with 31V bench power supply), but most often it won't. I cannot find out why. I tried to heat the board up from down below, but it didn't make any difference.
                          The power supply shows few mA for a moment, but then it goes into 0mA, so nothing seems shorted. The 1st 2 caps (around that burnt diode) get charged, but nothing else does.
                          I cannot work out how the rest of the board should get powered. Neither of the 2 DC-DC chips have any power either.
                          • CapLeaker
                            Leaking Member
                            • 8214
                            Cold solder joint or bad through hole maybe?
                            • redwire
                              • 3910
                              The new diode might be in backwards if I gave more bad advice? Cathode is away from the relays eek if "- from rectifier" is right in your drawings. If the pad has lifted off, you can use other pad, put it there like pic.
Name:	door opener diode.jpg
                              The fuse is good and has power? Check the TO-220 below it and the big resistors. Can you read any numbers on the TO-220 parts?
                              This supposed to be a 24VDC board but has 50V coming in? Must be a buck converter from 50V to 24V, the heatsink by the 24V relay below?
                              There are two buck-converters that have the blue inductors "101". If there is no power there, then look upstream.
                              I think it goes 50V raw in -> 24V ->12V -> 5V. This board is a bit crazy.
                              • jm1234
                                • Jan 2024
                                • 61
                                • Slovakia
                                #35
                                Found the issue, it was right between the chair and the desk. Mistake on mistake, but I did figure it out. I was tracing why those other caps don't have any voltage and it turns out there is another lower-voltage supply on the 3rd pin on that big connector. I was going off of my memory since I got back to looking into this, so that's what I didn't remember. The cases when I was able to make the board come alive must have been when I accidentally connected my power supply to that 3rd pin I guess.
                                What i don't understand is that voltage supply on 3rd pin comes directly from transformer (so bypasses rectifier) and when I measure it it shows 25VAC, but when I switched my multimeter to DC, it shows 7.5VDC.
                                • redwire
                                  • 3910
                                  There is that other rectifier diode on the board, it must 1/2 -wave rectify the 25VAC and there is that big blue resistor to drop it down.
                                    Lift Master garage door opener with WiFi capability application through your phone
                                    by sam_sam_sam
                                    I had a lot of trouble with the WiFi connection from my router inside of the house into a ( new ) metal garage I had to run a 150 ft cat6 patch cord so the WIFI connection would be strong enough for the WiFi connection on the garage door opener would work correctly ( my son has a work out area in the garage as well and he was having to put his phone near the door to be able to stream music ) ( so I was going to eventually put WiFi out there anyway )
                                    This garage door opener WiFi is very touchy if you lose the power it does not remember the password for the router which is weird or...
                                    01-21-2023, 08:31 PM
                                    Linear Garage Door Opener Control board took a crap install a new control board back normal
                                    by sam_sam_sam
                                    I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
                                    02-08-2025, 06:52 AM
                                    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                    by sam_sam_sam
                                    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                    I am comparing them to a brand new one that I installed
                                    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                    I going to let it run for several days before I remount back on the wall next to the...
                                    09-05-2024, 06:48 PM
                                    Linear Garage Door Opener Control Board Repair weak capacitors
                                    by sam_sam_sam
                                    I was having issues with the controller not always responding to remote control signal having to hold button until garage door started to move
                                    Now after replacing the two capacitors on the two 5 volt power supply rails
                                    One is used for the up/down limit up/down force circuits
                                    Second one is used for the radio receiver circuit
                                    The main filtering capacitor ESR value was a little higher than a new one
                                    https://www.northshorecommercialdoor...yABEgLxlvD_BwE
                                    09-03-2022, 12:15 AM
                                  • Cornboats
                                    Garage door opener-safety cutout faulty
                                    by Cornboats
                                    I have vintage Slavedor garage door opener that has stopped closing the door. If I disable the up/down current control to the motor it works fine. I've attached the larger control board which is for everything and the smaller current control board.
                                    Normally the current control is set slightly above the maximum current normally used. If the door exceeds this it should stop and reverse when closing or just stop when opening. Can someone please explain how the current control board works so that I can try and repair or replace the defective parts.
                                    I see my self as an interested novice...
                                    01-19-2023, 05:25 AM
