9V relay temperature 40C
  • jm1234
    • Jan 2024
    • 61
    • Slovakia
    Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
    I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but some appeared every now and then.
    Any input appreciated.
  • redwire
    • 3910
    What size is the relay? 9V coil is popular for appliances. Relay coils make heat so 40°C is reasonable. Heat is also made by the current flow through the relay contacts. So they can dissipate 0.5-1W or more and they will warm up.
    Some companies will use "peak and hold" where they pulse the relay at say 20kHz 50% duty cycle to keep the relay contacts in but the coil cooler.
    More often the problem is cracked solder joints or bad relay contacts.
      Mitsubishi CNC switching power supply board dead / relay board bad diode failure
      by sam_sam_sam
      I was working on this CNC machine today found no keyboard functioning no control relay powering on
      The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
      Found shorted diodes on main controller relays there are 3 of them that...
      01-07-2023, 05:43 PM
      by sam_sam_sam
      03-31-2024, 02:12 PM
      by sam_sam_sam
      07-01-2024, 06:34 AM
    • valvashon
      Repair Success! Middle Atlantic UPS2200R-IP
      by valvashon
      Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
      Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
      02-06-2024, 12:54 PM
    • CuriousJohn
      Burco boiler power problem
      by CuriousJohn
      Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
      Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
      This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
      12-22-2024, 10:25 AM
