Relay Satronic MMI 810.1 bad diode & Transistor
  • InsertCoin
    • Apr 2021
    • 11
    • Hellas
    Hello and happy new year ,
    my Analog Combustion Machine Honeywell gone bad and I don't know what type of diode is utilized.
    There is no mark around the body of the diode. The Schematics are general referred only, without any electronics components and values.
    The two contacts (2),(5) of the Relay Coil need 48 Volts DC to begin operating. Between these two contacts in series is the bad diode and near of contact (5) is the bad pnp (bc856b) Transistor that can be easily replaced.
    I have made a diagram of the PCB and some measurements along some points.
    Do you have any idea about what type of diode could be utilized ?
  • lotas
    • Jan 2016
    • 4614
    • Russia
    Usually a 1N4148 diode (150mA 100V) is installed in parallel with the relay coil.
    https://aliexpress.com/item/32802141687.html?
    • InsertCoin
      • Apr 2021
      • 11
      • Hellas
      Thank you for your answer Iotas, but here are in series not in parallel and that's why I can't really understand what type of diode need to replace..
      • lotas
        • Jan 2016
        • 4614
        • Russia
        This is in parallel with the relay winding!
        • lotas
          • Jan 2016
          • 4614
          • Russia
          And this is consistent.​
          • InsertCoin
            • Apr 2021
            • 11
            • Hellas
            Sorry for the previous draw it was wrong !
            Here the right one :
            • lotas
              • Jan 2016
              • 4614
              • Russia
              Are you talking about this D4 diode?
              • InsertCoin
                • Apr 2021
                • 11
                • Hellas
                Yeap, that's the bad guy !
                • lotas
                  • Jan 2016
                  • 4614
                  • Russia
                  But it stands in parallel with the relay.
                  • InsertCoin
                    • Apr 2021
                    • 11
                    • Hellas
                    Why in paraller ? Between contact 2 and 5 (which is the 48Volt relay) is the bad diode and as far I can understand it is in series, because the one end starts from contact 2 and the other end (of diode) terminates on the contact 5. Is that wrong ?
                    Click image for larger version  Name:	diode.jpg Views:	0 Size:	253.0 KB ID:	3179876
                    • lotas
                      • Jan 2016
                      • 4614
                      • Russia
                      This is parallel, not sequential, like in the photo.
                      • lotas
                        • Jan 2016
                        • 4614
                        • Russia
                        You need to understand what a parallel connection and a serial connection are.
                        • InsertCoin
                          • Apr 2021
                          • 11
                          • Hellas
                          Because the circuit is a bit difficult for my electronics level finding the voltage sources, and understand if the bad diode is in series or in parallel connection, do you believe a 1N4148 diode (150mA 100V) could make the job ?
                          • lotas
                            • Jan 2016
                            • 4614
                            • Russia
                            Yes. The main thing is not to confuse the anode with the cathode; it will burn out instantly.
                            • InsertCoin
                              • Apr 2021
                              • 11
                              • Hellas
                              Dear friend, thank you so much for your patience to answering in my questions and give solves to my problem ! If it will work then please let me donate you some euros... Because otherwise I would have to buy a new device or even a used one...
                              • lotas
                                • Jan 2016
                                • 4614
                                • Russia
                                Let's hope everything works.
                                  Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                  by sam_sam_sam
                                  I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                  The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                  Found shorted diodes on main controller relays there are 3 of them that...
                                  01-07-2023, 05:43 PM
                                • CuriousJohn
                                  Burco boiler power problem
                                  by CuriousJohn
                                  Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
                                  Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
                                  This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
                                  12-22-2024, 10:25 AM
                                • asr
                                  Finding replacement diode iPad Pro 3rd gen A1701
                                  by asr
                                  Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                                  Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                                  07-09-2024, 06:24 PM
                                • unimatrix93
                                  TV backlight zener diode
                                  by unimatrix93
                                  Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                  So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                  Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                  The led strips has 9 6V leds.
                                  02-10-2025, 12:13 PM
                                • ItepK
                                  Panasonic TX-P42G30E green light blinking, no video, no audio
                                  by ItepK
                                  Hey everyone!
                                  I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                                  This post describes my entire troubleshooting process of this TV.
                                  When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                                  I've taken the unit apart, and I've started to check some voltages:
                                  • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                                  12-22-2023, 05:06 AM
