Kiddie smoke alarm (120v with 9v battery backup) experienced 180v power surge (Newfoundland Power company).
  • Bubbsy 2002
    • Nov 2010
    • 56
    Hi to all, I was diagnosing 2 smoke detectors that experienced power surge. I opened one up and found a weird fuse/resistor, which now has open circuit. I can't find this part.
    Forgot to mention they both light up and I believe the test function works, but when I put smoke to them no alarm!
    Any help in this regard would be greatly appreciated.
    Thanks,
    • 31316
    it's a fuseable resistor.
    what does ZV1 say on it and is it shorted?
    • Bubbsy 2002
      Bubbsy 2002 commented
      Editing a comment
      Thanks again, RV1 looks like another resistor, it has PK on it and has some measurement (I got a .524 kohms). If you look at the word FAILSAFE it looks like it is not installed with this particular smoke detector. Forgot to mention they both light up and I believe the test function works, but when I put smoke to them no alarm!
      Last edited by Bubbsy 2002; 01-02-2024, 06:43 PM. Reason: Additional information added.
  • Bubbsy 2002
    UPS CyberPower CP1500AVRLCDa: Newfoundland Hydro company maintenance issue, voltage spike up to 180v!
    by Bubbsy 2002
    Hello to all,
    Like to wish you all fruitful NEW YEAR, as I have never seen anything like what we have experienced in the last 5 years.
    Again this is a first for me being 60 years old, first time I have ever saw a surge like this (I have seen lighting surge damage).
    My Cyber Power CP1500AVRLCDa was making noises like crazy and I could see the voltage spiking from 19v to 180v on 120v in my house. Fans and lights giving me quite the light and sound show (15 bulbs blew).
    I also lost my Venmar HRV EVO5 HEPA, Brother Printer HL-2270dw, Husky Central Vacuum, LIteSun...
    12-29-2023, 06:57 AM
  • Bubbsy 2002
    Halo 5 inch and 6 inch White Integrated LED Recessed Downlight, destroyed by 180v power surger (Newfoundland Power Company).
    by Bubbsy 2002
    Hi all, I am on a 100% diagnostic spree and need some more assistance.
    I have looked at the board of this poor light and it appears I have an fuse/resistor combo.
    I have isolated what I believe are RV1 (destroyed by the surge) and you can see RV2, so I am assuming they are same or similar.
    Can you tell me what the name of the component, amperage/resistance, so I can order from DigiKey?
    And now I noticed the light went up $10 Canadian, to $46.
    Any help in this regard would be greatly appreciated....
    01-03-2024, 12:17 PM
  • Tom41
    Honeywell Accenta G3 tamper alarm
    by Tom41
    This house has a Honeywell Accenta G3 alarm system. If the main unit loses power for any reason, the external siren sounds - even if the alarm is not even armed! Entering the code to disarm it is not an option as the keypads are completely dead when the power is out.
    I presume this means the backup battery inside the box has failed, but I can't get in there and replace it without also setting off a tamper alarm! Is there any way to disable the tamper alarm so that electrical work can be carried out with the power off? Or a way to replace the backup battery without setting off the...
    08-31-2023, 04:00 AM
  • slybunda
    Alarm Siren issue
    by slybunda
    Apologies if this is in the wrong section but being a car alarm siren that makes noise i thought it be best to put it in the audio section.
    Had weird alarm issues where siren made a strange noise: https://www.youtube.com/watch?v=ZjsqndhionU
    took siren out of the car and checked it out and pics attached seem to be the source of the issue.
    shockingly the alarm still makes its normal sound if i trigger it manually so speaker seems to be intact.
    getting a replacement is gonna be next to impossible, its a Toad Ai606 which is no longer in production and cant see to find a replacement...
    02-04-2024, 11:01 AM
  • Ady2017
    Does anyone know about 16x2 LCD screens used in alarm keypads?
    by Ady2017
    I have got an old Gardtec GT595 alarm which has got a faulty keypad with a failed LCD screen. This was apparently a very common problem with these and many people have had to replace the whole alarm because of this problem. Somebody claims to be able to repair the keypads by replacing the screen and I have tried it myself by replacing the LCD with a commonly available HD44780 1602 16x2 Serial LCD screen but it is not working. I am sure it is a problem with a driver or simular which is not allowing the screen to talk to the rest of the electronics. Does anyone know what this original screen was...
    06-02-2025, 04:56 PM
