Signal Booster repair
  • badcapjerboard
    • Apr 2023
    • 68
    Can anyone please help me identify the chip needed for replacement?
    Seems the dc jack breaking off the board broke this device. There is a chip with a hole blown through it which I removed, but I can't tell what was written on it or get any useful info with a meter. I'm assuming it's a transistor.
    It looks the same as a chip nearby which says 4R_s 94 but clearly said something different. Can anyone tell me what is an appropriate replacement or how to figure it out?
    blue arrow removed chip. also knocked out little capacitor below it.
  • CapLeaker
    Leaking Member
    • 7999
    I don’t think it is a transistor like a NPN or PNP, more like a Zener diode or something like that. Look at the trace and pin config where the SOT-23 device was, You got the traces for bottom 2 pins together where the SOT-23 on the PCB would be. Wouldn’t make any sense having a transistor there, other than that the other amps would have to have the same transistor and they do not.
    Maybe the SOT-23 marking is Z7 = 8.2V Zener.
    • badcapjerboard
      • Apr 2023
      • 68
      Thank you. Appreciate it! Will try to find one and see what happens..
      • CapLeaker
        Leaking Member
        • 7999
        Anyway, that's all I could come up with… look at the broken SOT23 with you DMM in diode mode and check the pads on the board, not that something else is shorted to gnd as well.
        • badcapjerboard
          • Apr 2023
          • 68
          Ya, the pads are all shorted to ground still. I can't get a reading with a dmm on the blown chip.
          • CapLeaker
            Leaking Member
            • 7999
            check out the mlcc smd cap next o it on the right
            • badcapjerboard
              • Apr 2023
              • 68
              The big cap to the right on my esr meter showed as ref for 25v e cap good if cap <47 uF
              But right above that, second to the right shows as bad cap with high esr. I removed it and it didn't change anything.
              • CapLeaker
                Leaking Member
                • 7999
                the top and the bottom right pad of the SOT-23 are joined together. The bottom left pin is GND. There has to be a through hole and probably the story continues on the other side of the PCB.
                • badcapjerboard
                  • Apr 2023
                  • 68
                  What a pain. the connectors at both ends were soldered onto the board so that I had to desolder them to get the board out. And the bottom of the board has a metal plate attached so I can't see the traces.
                  • CapLeaker
                    Leaking Member
                    • 7999
                    yeah... it's shielded all right. That's a pain in the rear to get off, if you don't have the right equipment.
                      by SMDFlea
                      Bad...
                      09-02-2021, 04:40 PM
                    • BMCappelletti
                      Asus Chromebox CN62 - wrong chip put on BIOS reader
                      by BMCappelletti
                      Long story short:
                      - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                      - gave the computer to his son a couple years later
                      - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                      - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                      (seems like the story was not that short)
                      He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                      01-08-2025, 07:27 PM
                    • Troystain
                      Help EZP2023+ updated chip database for w25q256jveq?
                      by Troystain
                      Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                      I need to add w25q256jveq chip but I do not know what data should I type.
                      I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                      The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                      11-25-2024, 12:53 AM
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                    • inck243
                      Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                      by inck243
                      Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                      The BIOS...
                      07-25-2024, 09:17 AM
