Aircon regasser,Could bad caps be the problem here?
  • CptChronic
    • Jul 2022
    • 39
    • United Kingdom
    I have this aircon regasser in from a friends garage. The values fluctuate on their own when they should be giving out a solid reading. My first thought was capacitors so I have replaced the lot, just looking for a second opinion before taking it back for testing. One of the 10uf capacitors had an ESR of 1.8ohms the new ones I have fitted are a little less. Hoping this will solve the problem, I can't find any shorts or other faults on the board but as I don't have a schematic I'm not 100% sure what readings I should be getting.
    Pictures here: https://imgur.com/a/FVSajwR
  • andrewsawesomr
    • Jun 2022
    • 100
    • United States of America
    Re: Aircon regasser,Could bad caps be the problem here?
    You did check the battery voltage, correct?
      • Jul 2011
      • 6039
      1.8 ESR reading might be a little bit high depending on the type of circuit that you have
      Because on some switching power supply circuits get flaky when ESR is higher value than than a new one
      Keep in mind that an ESR does not put the capacitor under a load condition and sometimes a capacitor can check on a meter but fails under a load condition
      • CptChronic
        • Jul 2022
        • 39
        • United Kingdom
        Sorry guys, I didn't realise there was any replies here.
        I did swap the battery and all the caps, on the bench the board had solid readings so I was 99% sure I had fixed the problems.
        But when I went to test on the machine, it had the same results.
        The bosch engineer said he had swapped the scales which is an all out lie, he then blamed everything on the circuit board. I have the whole thing here now and am unsure what more to do other then swapping some of the chips.
        The scales seem to be working as when I pull on the bottles the value does increase but when left at their usual state the value fluctuates which is what is confusing me.
        I have some pictures of the scales and a video of the fluctuating values here: https://imgur.com/a/LVcUhxW
        • bulkchart32
          i think i accidently ordered non-polarized 10uf caps for my original xbox. will this cause a problem?
          by bulkchart32
          i ordered a lot of caps from digikey to repair my xboxs. one thing i ordered was 50NXA10MEFC5X11-ND caps and i think they are not polarized. will this cause any kind of a problem? i really don't want to order new caps just because of this.
          06-16-2025, 03:09 AM
        • dclass-pro
          Hp DAOP5FMB6A0 blink caps/lock problem
          by dclass-pro
          Hi guys, I have an HP model 15s-eq1040nl main DAOP5FMB6A0 REV:A with a caps/lock 5 long 3 short led flashing problem, I tried to remove the battery and program a new bios and when I restarted it immediately worked correctly, the pc turned on and loaded the operating system.
          As soon as I turned off the pc and connected the battery, the problem reappeared... caps/lock 5 long 3 short led flashing again!
          the battery was dead, i charged it and it works fine, but the pc won't turn on again.
          What do you recommend me? Do I have to redo the bios or is there anything else to check?...
          05-08-2023, 12:46 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • looxuser
          why is my problem fixed when I ground caps?
          by looxuser
          I have an audio device with two caps around an ic amp JRC2073. I replaced these two caps and the no audio fault remained, however by chance i shorted the exposed caps of these two with a finger each on one hand and got audio. My hand resistance was about 0.4mohn so i tried large resistor across instead and got audio too, why is this please? All the solder joints look and test good.
          06-04-2023, 03:36 PM
